Engine building resources
Old Mar 26, 2009 | 05:16 PM
yamaha16bw's Avatar
Originally Posted by SoFloTC
Originally Posted by yamaha16bw
Another FYI....
Maybe everyone knows this....I didnt.
Cometic offers HG's in every bore. Most are custom orders.
I had to order a 89.5 mm bore HG due to my 89mm pistons.
i got 89mm pistons and i used a 89mm HG...... it fit perfectly... i was told when the HG says 89mm it means its USED FOR a 89mm bore is this correct or not?
Ive always been told to use .5mm over the piston bore.
stock is 88.5mm and cometic's start at 89mm.
Either way I'm sure your fine.
Old Mar 26, 2009 | 05:52 PM
vettereddie's Avatar
Hey guys, xB owner here. One of the (comparitively) few cracking open the 1NZ-FE. I got this book for my build and found it very helpful, especially on the balancing and assembly chapters. The only tools I was missing were an interior micrometer for and a telescoping bore gauge. The engine tech is a little dated but to be honest, short block technology hasn't moved in the last 30 years, only the head.
http://www.amazon.com/Blueprint-Buil...8089493&sr=8-1
Old Mar 26, 2009 | 06:44 PM
TCpete's Avatar
Originally Posted by paul_dezod
Originally Posted by gingles
tc pete....what k or b series parts fit the tC?
A certain engine stud...............................................
haha thats 1 part but their are more alot of trial by error on my part... and alota bent valves later success..lol
Old Mar 26, 2009 | 06:51 PM
paul_dezod's Avatar
Scionetics
KAD
oh I know..................
Old Mar 26, 2009 | 07:22 PM
TCpete's Avatar
know as in part or know about how much a PITA its been working on the tc lol
Old Mar 26, 2009 | 07:44 PM
aen's Avatar
aen
can you guys specific? it's like it's a trade secret and you don't want to tell us or something
what honda parts fit? head studs?
bearings?
Old Mar 26, 2009 | 07:51 PM
gingles's Avatar
aen me and you are on the same page....geez spill the beans guys
aen's Avatar
aen
Another FYI....
i have never heard of using a head gasket that isn't flush with the bore
Old Mar 26, 2009 | 07:52 PM
aen's Avatar
aen
Originally Posted by RSracer
FYI, I had calico coat my main/rod bearings and thrust washer and it was only $70 with return shipping. I sent in my bearings since they didn't have ACL race series and got them back in 4 days.
which bearings did you coat?
Old Mar 26, 2009 | 08:17 PM
gingles's Avatar
main and rod bearings and thrust washer is what he said
Old Mar 26, 2009 | 08:20 PM
aen's Avatar
aen
i know, but i mean stock bearings, acl bearings clevite bearings blah blah
Old Mar 26, 2009 | 10:13 PM
yamaha16bw's Avatar
shouldnt matter about the brand....
ever bearing that doesnt meet toyota spec's should be coated and that will happen prolly like 90% of the time.
Old Mar 26, 2009 | 10:25 PM
aen's Avatar
aen
well, dependin on the brand you get different materials, different hardnesses that are available and different spec clearances...that's all i meant, i mean you could get stock bearings and get them coated, but are they as strong as clevite bearings that are coated?
knawmeanhomiegslicedawg? lol
Old Mar 26, 2009 | 11:25 PM
yamaha16bw's Avatar
Ahh. I C
Old Mar 27, 2009 | 01:17 AM
aen's Avatar
aen
Ahh. I C
so i'm going to need, rear main seal, head gasket oil pump and thermostat gasket from toyota?
i just saw that their kit is like 300 dollars
Old Mar 27, 2009 | 01:20 AM
gingles's Avatar
why would you get the oem head gasket instead of cometic?
Old Mar 27, 2009 | 01:26 AM
aen's Avatar
aen
im not, that's why i was asking which ones i need to get so i can pick it seperately and create a list in the first post
otherwise i'd just get the engine overhaul gasket kit
Old Mar 27, 2009 | 01:41 AM
RSracer's Avatar
My bad, I guess i wasn't very clear. Since I wanted race series ACL I had to buy them from ptuning and send them to calico since they don't stock the race series.
My friend used to work for two nascar teams as their engineer and they all swear by Calico's CT-1 bearing coating.
Old Mar 27, 2009 | 03:07 AM
yamaha16bw's Avatar
I dont see how a gasket for our cars would cost 300.....i know the main seal's cost like 66 for the big one and 20 something for the pulley side.
Not sure about the OEM HG. I went with Cometic and paid 75 for it.
So no way should a "kit" add up to 300. Way too much IMO.
Old Mar 27, 2009 | 03:58 AM
aen's Avatar
aen
it included everything from the main seal to the head gasket, and exhaust gasket and intake manifold gasket
it made somewhat sense, i jut ddon't need alot of it so i figured i'd piece it together instead
