The finest in fuel injection is here at Dezod...
Not only do we carry Deatsch Werks, but we also now offer Injector Dynamics!
We will be stocking 725s and 1000s. Our stocking order should arrive sometime in the next few days.
Dynamically Matched Sets
Injector Dynamics fuel injectors are the result of batch testing large quantities of specially modified fuel injectors, and then carefully matching them into sets based on their dynamic flow across the pulsewidth range. The result is vastly superior cylinder to cylinder consistency, even at very low pulsewidths.
In addition to receiving tightly matched injectors, you will be provided with dead time compensation values across the entire pressure and voltage range of the injector. This data will insure that the compensations in your ECU work properly, and your air fuel ratios will remain consistent as atmospheric or voltage conditions change.
Full Dynamic Characterization
We provide the data that you and your ECU need to do the job properly.
Flow and offset values are provided from 8 to 16 volts across the full pressure range in 5 psi increments.
Additionally, we publish full dynamic characterization curves: Raw flow vs pulsewidth, offset corrected flow, linearity curves, and pressure sensitivity plots.
More info:
http://www.dezod.com/pd-injector-dyn...7-xb-08-10.cfm
steeze69
May 24, 2021 02:57 AM
vi3tb0i09
Sep 23, 2015 08:32 PM
