First Problem in years (white smoke of doom)
I finally ran into an issue.
The car is shooting white (im pretty sure its white not blue) smoke out of the exhaust
and also shooting it out of the valve cover breather thing.
If i pull the dipstick while the car is running, the white smoke comes out of the dipstick hole.
Also, My coolant level went down about 1 inch since yesterday, so im assuming that Im burning coolant.
Sounds like a Head Gasket issue?
Any and all suggestions are welcome and wanted
thanks guys
thanks guys
Originally Posted by jonathan110987
mine did that when my piston rings went out.
if so, its time for that good ol motor build
Blown head gasket no big deal? I'd say that depends on how it blows. Have you checked the oil on the dipstick? Does it look normal or kinda like chocolate milk? If the latter, then water has mixed with the oil and there will be a lot more damage if continuing to run. Maybe you got lucky and the gasket blew such that the water isn't contaminating the oil, I certainly hope that's the case for your sake.
your rings are shot bud. white smoke coming out of the dipstick is a tell tale sign of blow by aka blown piston rings. do a compression check and post the readings but nore than likely your in for a motor build
thanks for the replies guys.
no, the oil from the dipstick looks normal
however on the valve cover hole, when the smoke comes out a little oil will come out too, and its milky.
but the oil on the dipstick looks perfectly normal, and my oil level is fine.
im planning on doing a compression test soon.
ya, either way.
im probably gonna throw some decent rods and pistons in there.
at least some good will come out of it.
yeah i will not be driving the car
instead ill be riding my bike with no license lol
Originally Posted by pwee08
Originally Posted by ElevationTC
keep us posted!
UPDATE
sorta lol
cars been sitting for 2 months
still havent got a compression test
i put the car back to stock (keeping the turbo though) and ill be doing a compression test asap.
BTW when i drained my oil it looked perfectly normal
sorta lol
