First Problem in years (white smoke of doom)
Old Jul 7, 2009 | 07:58 PM
Ace83's Avatar
Ronin Scion
how does it run on the stock setup? I just do a mild build man, piston, rods and headgasket..
Old Jul 7, 2009 | 08:28 PM
Jan06xB's Avatar
You might try a quick retorque of the head and of course check the spark plugs because if they are wet then you know which cylinders are leaking. You could also have a leak along the intake manifold if there are coolent connections there. Another thing to check is pressure in the radiator when you start it up - cylinder leaks make radiator pressure jump right up - exhost head leaks not so much pressure.
cavalierkid888
Jan 8, 2015 04:42 AM
wizzlexB
Dec 27, 2014 04:06 AM
fluxingnation
Dec 26, 2014 04:28 PM
mrbadass03
24
Apr 21, 2004 02:17 AM
showpaojoe
Nov 26, 2003 02:38 AM
