Greddy Emanage Ultimate Limp Mode
Old Mar 29, 2009 | 07:28 PM
rhythmnsmoke's Avatar
Music City Scions
Need a tune.
Old Mar 29, 2009 | 08:54 PM
ValenciaS's Avatar
i think im having the same problem car was pulling fine i just installed the kit 1 week ago now its not even pulling at all its like its running of the stock ECU, how do i get it to run back on the map ? or get off LIMP mode ?
Old Mar 29, 2009 | 09:21 PM
dodaddy's Avatar
^^ temporary fix is disonnect your battery for a minute then plug it back in
Old Mar 29, 2009 | 09:26 PM
ValenciaS's Avatar
I tried that , its not working should disconnect my MAF sensor ?
Old Mar 29, 2009 | 09:36 PM
ValenciaS's Avatar
i tried disconnecting the MAF sensor its even worse so i put it back on , the car feels stock with a turbo kit on it oh my god
Old Mar 29, 2009 | 09:53 PM
dodaddy's Avatar
maybe the map didn't get uploaded correctly to your emanage?
Old Mar 29, 2009 | 10:41 PM
Music City Scions
How much boost is your gauge reading?
Old Mar 29, 2009 | 11:21 PM
ValenciaS's Avatar
im not getting any boost at all . It has to be running on the stock ECU , right now i unplugged the Negative battery terminal , and i disconnect the ECU harness from the car and im letting it sit for a moment
Old Mar 29, 2009 | 11:38 PM
UNiT_xEr0's Avatar
DelMarVa
haha this is the same problem i have. my spark plugs got fouled out so i changed them. put new ones in and they got fouled out cause i was boosting. its in the tune. so i say check your plugs if they are fouled out change them and baby it to the tuner. thats what i'm going to do this wednesday and i posted a thread about this too
Old Mar 29, 2009 | 11:41 PM
UNiT_xEr0's Avatar
DelMarVa
i'm running FIC btw so i'll post up what the outcome on wednesday
Old Mar 30, 2009 | 12:10 AM
ValenciaS's Avatar
Oh ok i will try that thanks what kind of spark plugs should i get ?
Old Mar 30, 2009 | 01:59 AM
ValenciaS's Avatar
ok guys i changed the spark plug car is still running the same , feels like the stock ECU took over i don't know how to get the management working on it. Do you think the management lost the tune ? and i smell alot of gas and i mean alot
Old Mar 30, 2009 | 02:29 AM
ValenciaS's Avatar
someone please help
Old Mar 30, 2009 | 03:22 AM
BlackKnight's Avatar
Music City Scions
You need to find a tuner that fully understands that system then and go to them.
Old Mar 30, 2009 | 03:33 AM
UNiT_xEr0's Avatar
DelMarVa
i dont know anything about the emanage. i know for the FIC after i changed the plugs it still ran stupid until i did the resitor mod. so i say check your plugs again disconnect the battery and go from there. and absolutely get it tuned. in socal i have churches tuning
Old Mar 30, 2009 | 02:34 PM
ValenciaS's Avatar
What if my stock ECU is running in Limp mode or somthing , i mean i can drive the car normal its running fine it just seems like my greddy ultimate emanage is not even working. Is there anyway i can check to see if the map is active ? also all my DIP switches on the ultimate are set to off.
Old Mar 30, 2009 | 03:25 PM
Ptuning_tuner's Avatar
I don't think that anything is necessarily wrong with your factory ECU or e-manage. Check to make sure that ALL the intercooler pipes and intake pipe are not loose or even popped off. Let us know what you find out.
- Toan
Old Mar 30, 2009 | 03:59 PM
brett561tc's Avatar
the solution for the common piggyback...
http://www.dezod.com/pd_dezod_motors...standalone.cfm
Old Mar 30, 2009 | 04:40 PM
ValenciaS's Avatar
- Toan
All the pipes seem to be nice and tight nothing is popped off that i know off, I just changed the spark plugs, the stock ones were burned and black. I tried discounnecting the battery/harness and everything else and nothing yet. Im going to double check the pipes. If its a boost leak it has to be a pretty big one. The car was running great for about a week, after that week everyday it got slower and slower. And I always babied the car it only has 7,XXX miles on it, and its a manual transmision.
Old Mar 30, 2009 | 05:20 PM
Music City Scions
Hydra > AEM
