GReddy Turbo Oil Feed Line and Fitting Diagram for replacement
Hi everyone.
I know this car and the kit is kinda old but if any one of you are getting a used GReddy kit and the oil feed line or the fittings needs to be replaced I made a diagram so you guys know what to get.
By the way the greddy kit install pdf has a typo about the fittings so it was kinda confusing for me.
Here is the diagram:
Basically PT is a regular thread and PF is a flared thread. BSPT thread might be the same. Not sure about it.
What was confusing to me is that in the pdf file they never tell you that the M10 thread with the copper washer needs to go in to the top of the turbo and the PF side needs to go in to the oil feed line.
PDF shows that this fitting is an M10 on one side and 1/8 PT on the other side. WRONG! It is 1/8 PF on the oil feed side.
It might be clear to some of you which fitting goes where but the thread on my fitting was super bad so I couldn't tell which one goes where. And I couldn't drive the car to a hose / hydraulics shop so they could check the thread on the turbo.
The oil feed line cost $95 from GReddy and the 1/8PF - M10 fitting is an additional $10 or so. Plus shipping. Another $40 if you need this overnight because you need your car ASAP.
Local hose/hydraulics shop got me all these fittings and feed line for $50 Even included the Teflon already applied on the fitting.
I hope this will help out somebody.
If it's something is not clear message me.
__________________
__________________
Hi everyone.
I know this car and the kit is kinda old but if any one of you are getting a used greddy kit and the oil feed line or the fittings needs to be replaced I made a diagram so you guys know what to get.
here is the diagram:
Attachment 16314
What was confusing to me is that in the pdf file they never tell you that the m10 thread with the copper washer needs to go in to the top of the turbo and the PF side needs to go in to the oil feed line.
PDF shows that this fitting is an m10 on one side and 1/8 PT on the other side. WRONG! It is 1/8 PF on the oil feed side.
The oil feed line cost $95 from greddy and the 1/8PF - M10 fitting is an additional $10 or so. Plus shipping. Another $40 if you need this overnight because you need your car ASAP.
Local hose/hydraulics shop got me all these fittings and feed line for $50 Even included the teflon already applied on the fitting.
If its something is not clear message me.
Attachment 16314
http://www.dezod.com/pd-bspt-male-to-female-18-npt.cfm
http://www.dezod.com/pd-brass-18-npt...ee-fitting.cfm
You need the BPST? or the T? Or what?
Is my first post really that confusing? I have everything all fixed up but thanks. I just wanted to post this up because I spend a whole night trying to figure it out what's up with the fittings
and I saw hundreds of universal oil feed lines on eBay but I didn't know which one to order because I wasn't sure whats going on with the fittings. Also saw dozens of forum posts when I Googled it.
That GReddy install pdf should be more clear and they should correct the typo. Already spoke to someone from GReddy to clarify the fittings. And the guys was like: Uhm... there is a typo on the pdf. The feed line receives pf fitting not pt.
Everything is all cleared up and a local hydraulics / race hose shop already gave me everything I need. Btw thanks for Clutch. I just got them installed a few days ago. It bites like crazy. I still need to get used to it. ( I am Csaba [Shaba])
__________________
__________________
cabrera1985
Regional - Pacific South
02-09-2012 05:02 AM
recliner15
13
01-06-2008 02:40 PM
bruiserTC
08-04-2006 07:02 PM
