Head Gasket
So Im going to be starting my built motor project here soon, And Ive noticed something. It appears alot of the built motor guys are using an OEM head gasket, not the Cometic? Im just curious about this, is there an issue with the cometic on our block? I remember back in the day some Honda folks had issues with cometic gaskets leaking water and/or oil from the sides of the block. Just curious as to why Ive seen alot of the built motor guys go with an OEM HG.
I am willing to bet those honda guys also had ARP head studs and only torqued them down to Honda specs and not the ARP torque specs.
That could def be the case, also torquing with different assembly lubes will cause the actual torque on the stud to vary. I just remember seeing it on the Honda-tech forums a year or two ago and wondered why I had seen people on here using OEM headgaskets on builds when the price diff between the cometic and OEM is very marginal
From my exp...I have ALWAYS used a stock type head gasket. Higher block pressure and that will more than likely be the first thing that blows out. Id rather have some coolant to swap and a head gasket...then worry about the hole in something else
BlingSlade
Sep 5, 2015 08:52 AM
