help AEM F/IC
alright, soo i tried the gas test. didnt work. I took the power and ground wire directly to the battery and then tried the rag soaked in gas with the car off and on for about 2 minutes. does this garenttee that the sensors bad?
My bad, thought you were talking about setting up the fic. The wide band is already set up and ready to run right out of the box. There is not a way to adjust it. You can how ever change the read out from afr to lambda.
quickest and easiest solution to ur problem connect back the stock computer it will adjust its self and stay out of boost i should idle and drive fine just take it str8 to th tuner when u can the stock ecu and injectors car should run like stock that how i boost ever scion i do
SloTC1
Aug 16, 2018 02:45 PM
vi3tb0i09
Sep 23, 2015 08:32 PM
