help a boosted tc with a tranny problem
Old Sep 29, 2009 | 03:15 PM
streettimetc's Avatar
Default help a boosted tc with a tranny problem
posted in drivetrain (tranny noise 5th gear only) you guys in the fi section seem to more helpfull then the some people in the drivetrian and power section.
Old Sep 29, 2009 | 03:24 PM
m6ar2cel6oTC's Avatar
thats not much help what so ever.
Old Sep 29, 2009 | 03:59 PM
SoFloTC's Avatar
whats it sound like.. does it ever pop out?
Old Sep 29, 2009 | 04:29 PM
its never poped out of gear. but it sounds like the whine of a roots type s/c.but i only hear it when i let off the gas in 5th gear. at higher speeds and rpms its louder and higher pich. at lower speeds and rpms its quiter and lower pich. it sounds like im driving a dogboxed wrx or something. i think i have a bad bearing in the tranny. that would suck!
Old Sep 29, 2009 | 04:45 PM
ack154's Avatar
Considering that you JUST posted that in D&P today and have zero replies... I think that's a pretty crappy judgement.
Not to mention there's no need to double post. I've locked the other one.
Old Sep 29, 2009 | 04:46 PM
juancho's Avatar
i have dat issue shiftin from 1st to 2nd n at times it pops out of gear???? why does dis happn
Old Sep 29, 2009 | 04:50 PM
ElevationTC's Avatar
sounds like your diff is whining!
Old Sep 29, 2009 | 04:54 PM
juancho's Avatar
is that the reason it pops out of gear?
ack154's Avatar
Because you use words like "dis" and "dat" instead of typing one additional letter to make the actual word?
Old Sep 29, 2009 | 04:57 PM
juancho's Avatar
lol sorry but jst have been trying to figure that problem mr. mod
Old Sep 29, 2009 | 05:04 PM
ack154's Avatar
It's OK, just a personal pet peeve of mine when people type some sort of shorthand which saves them next to zero typing and (IMO) makes them look less intelligent.
Good luck w/ your problem though.
Old Sep 29, 2009 | 05:40 PM
SoFloTC's Avatar
if it pops out of gear id suggest getting a tranny fluid flush and get some Redline MT-90 fluid to put in.. if it continues you synchro might be bad
Old Sep 29, 2009 | 05:42 PM
CSUnited14's Avatar
ack lol you just used a ton of abbreviated words.. but im not pointing fingers
Old Sep 29, 2009 | 05:46 PM
ack154's Avatar
Oh I know...
But an acronym like IMO is quite widely accepted and saves quite a few letters when typing. Compare to "dis" or "dat" which saves 1 letter and makes the person sound uneducated or from a ghetto.
The "w/" is a habit of mine but also a bit more widely used. Sure, it only saves 2 letters... but at least I'm not changing letters to make a whole other word.
Old Sep 29, 2009 | 05:58 PM
davedavetC's Avatar
idk wat da problem iz w/u ack but u need ta chill dood
Old Sep 29, 2009 | 07:47 PM
yeah thats what my frist thoughts but why only in 5th gear?
Old Sep 29, 2009 | 08:01 PM
the reason for that was so i dont get flammed on for a tranny problem in the fi section. and 90% of the time im on scionlife. im here in the fi section reading about everybodys builds. and for the most part everyone that post here are verry knowledgeable about what the say. so can we stay on topic and not worry about double posting and or shorthand typing. i use nentendo wii for internet. i short a lot.
Old Sep 29, 2009 | 08:10 PM
CarbonXe's Avatar
'Dis' and 'Dat' aren't abbreviated words.
Old Sep 29, 2009 | 08:43 PM
Steventc07's Avatar
You aren't the only one. Given I do it sometimes too, but for the most part I would rather type correctly. Plus if i have something mixed up car related or a have a mechanical misconception of sorts, my good grammar may save me from looking like a TOTAL retard .
Old Sep 29, 2009 | 09:22 PM
aen's Avatar
aen
whine with teh clutch in at idle? - throw out bearing
whine with clutch in and brake in only while in gear? - check teh clutch adjustment
if it pops out of gear it's hte synchros
my professional diagnostic is that it's a throwout bearing because it only whines and is louder in higher gears test a couple things, push clutch in at idle, if it whines let us know. if it doesnt let us know....could be a load of different htngs
as for your problem, it could range from the pressure plate being broken, the synchros blown or the clutch springs are snapped.
