help a boosted tc with a tranny problem
Old Sep 30, 2009 | 09:04 AM
aen's Avatar
aen
i suppose you dont' really care about your problem do you?
Old Sep 30, 2009 | 07:31 PM
streettimetc's Avatar
well yeah i do but i pulled the cheack/fill plug and some oil came out it still was on the clear/clean side. not burnt smelling with a hint of metalic. ok normal. but i ran a magnet thorgh the fill pulg and out came shreades of metal. so im going to drain flush and refill the tranny and get ready for a new clutch flywheel and tranny rebuild.
Old Oct 1, 2009 | 03:11 AM
t_urbo_C_harged's Avatar
If it is only in 5th gear, then you could have bad 5th gear needle bearings (not common, but I have seen it with a few gm tranny's) From my experience, if it only makes noise in one gear, then usually it is that bearing that's bad. Bad/worn synchro's (dogteeth) will cause it to either be hard to get into gear or will pop out of gear. Can't diag over the internet, that's for sure.
Old Oct 1, 2009 | 04:11 PM
aen's Avatar
aen
our trannies don't have needle bearings if i recall correctly..
the only needle bearings would be in the throw out bearings
Old Oct 2, 2009 | 12:03 AM
Lack of knowledge of our tranny haha. I have seen a lot of GM transmissions and it seems like they all use them (well, all Longitudinal haha) I will have to research the Toyota transmission.
Old Oct 2, 2009 | 01:24 AM
aen's Avatar
aen
i didn't mean any disrespect or anything as you're actually trying to help somebody...anywyas, heres hte tc's tranny. no needle bearings just helical cut gears on a long input shaft
Old Oct 2, 2009 | 01:26 AM
aen's Avatar
aen
either something is very wrong with your transmission or you drve the ____ out of it beacuse the stock tranny is strong as crap.
Old Oct 2, 2009 | 01:37 AM
SoFloTC's Avatar
ya lol.. u flat foot shift alot? or something? like the damage u would have to do to get ur tranny to start shedding metal is ridiculous
Old Oct 2, 2009 | 02:33 AM
Nice picture! Seems like it would be pretty easy to work on. I am still looking to get a Camry transmission and dissecting it to see the real differences in them. I Still want to swap the main shaft and the Ring gear if possible (for the slightly longer gears). I don't know how much it would actually help for boosted tC's, but I assume it wouldn't hurt since our gears are so short. I researched all of this a long time ago haha.
Dmmcclair
Aug 13, 2015 07:14 PM
kleecker
Apr 4, 2015 02:37 PM
kleecker
Mar 17, 2015 12:15 PM
yhwhdesign
10
Feb 6, 2015 05:00 AM
gularti
Dec 4, 2014 01:21 PM
