Help...Please
Background on the car: 2007 TC Dezod stage 1 w/ 700CC injectors and AEM F/IC (untuned - only base map at the moment)
Problem:
My car keeps giving me the "Charging system warning light" and "Low engine oil pressure warning light." Here is the thing, it only does it when i come to stops if the car is idled up it never does it.... at first it only happened a couple times and in reverse...so i thought it was just a fluke I just shut it off, let it sit for a while, then she's start right back up and no problems...now it happens randomly...stop signs...red lights...
Today, I hit a little bit of boost through 1st and 2nd and when I got off the throttle it died completely....giving me the "Charging system warning light" and "Low engine oil pressure warning light." I tried to start it back up and she was NOT having it..wouldn't start....finally i DID get it started and it idled like C R A P! So, I reset the ECU and all (by unplugging the neg battery wire) and it started back up...it idled rough for a second (like it always would if you reset ECU) and it idled OK but when I give it a little it of gas, the RPM's drop to like...300 and SOMETIMES it catches itself or sometimes it just dies...
Also, there are NO oil leaks of any kind...
Any help guys?? I'm supposed to get tuned Friday but I'm afraid to even drive it to the tuner now...
Problem:
Why would it only give the warning lights when it is at idling RPM's tho? It only gives the warning lights when I let off the gas and TRY to let it Idle...it's like 1200RPM'S and under the lights will come on and just shuts off..for safety reasons I'm assuming...
Originally Posted by bruceg
If ALLL those problems are REALLY due to my larger injectors how the hell would I go about getting a good base map for it? My tuner is not exactly down the road...
...btw. you're making yourself sound really snotty for someone thats asking for help.
yeah it should be the injectors, its big and it prolly needs you to give more air and fuel at idle than idle a stock injectors.. so when you let go off throttle you stall coz you dont have enough air/fuel.. i dont know man its just my guess.. but is your basemap set at 700 cc injectors?
I found something that sasy injector response time...would that be it?..whatever it is is set to 486 right now and it's measured in: uS so it looks like this: Injector response time: 486 uS. and where it says 486 you can input whatever you want.
