Help...Please
Old Feb 25, 2008 | 01:00 AM
Ace83's Avatar
Ronin Scion
bump for ya.. looks like the FIC guys arent posting yet
Old Feb 25, 2008 | 01:01 AM
bruceg's Avatar
lol yeah...i just need to know how I can change the injector size on the Dezod map..if you can maybe that will fix my problems.
Old Feb 25, 2008 | 01:05 AM
Ace83's Avatar
Ronin Scion
paul's gonna send you a map anyweiz, you can just compare it to what you have.. did you check the manual? or here maybe this will help
http://forum.aempower.com/forum/index.php
Old Feb 25, 2008 | 01:07 AM
Crippie's Avatar
1UP Crew
hmm.. i had read something about inputting the injector size for the fic.. i think it went like :
If larger aftermarket injectors are installed, the fuel map must be adjusted to compensate for the larger flow rate of the aftermarket injectors
Correction = (stock injector/new injector) -1
ex: 240cc to 370cc lb/hr injectors: = 240/370 - 1=-35%
dont know if that'll help, but its in the instuctions for the install. Hope it helps
bruceg's Avatar
Yeah, i got the Dezod map already...i just think the reason why it's acting up is because my injectors are bigger than the ones for that map.
Old Feb 25, 2008 | 01:10 AM
bruceg's Avatar
but where do i actually input that?
So I'm assuming stock is 240CC? so what would it be for 240 to 700?
Ace83's Avatar
Ronin Scion
never mind I just saw your post there on the forum lol
Old Feb 25, 2008 | 01:12 AM
Ace83's Avatar
Ronin Scion
if stock is 370 cc so 700 should be around 95% or something
Old Feb 25, 2008 | 01:15 AM
Crippie's Avatar
1UP Crew
i got -47%
Old Feb 25, 2008 | 01:16 AM
bruceg's Avatar
Whre do I actually input that information on the map though?
Old Feb 25, 2008 | 01:17 AM
Crippie's Avatar
1UP Crew
working on it
Old Feb 25, 2008 | 01:18 AM
bruceg's Avatar
Old Feb 25, 2008 | 01:23 AM
Crippie's Avatar
1UP Crew
i couldnt find it in the forum, but if youve got a laptop, you might wanna go out and connect it to the fic. perhaps theres a tab that allows you to change the % of fuel going to the injectors... not sure... sorry couldnt be of more help
Old Feb 25, 2008 | 01:26 AM
bruceg's Avatar
I got the program on both my laptop and my desktop comp. I have the map open on my desktop now, just don't see anywhere that allows me to input than information, unless I'm overlooking something.
Old Feb 25, 2008 | 01:43 AM
Crippie's Avatar
1UP Crew
im not sure, but i believe you have to have the unit connected... not sure
Old Feb 25, 2008 | 04:08 PM
bruceg's Avatar
I'll try to connect it and see.
Old Feb 25, 2008 | 04:23 PM
bruceg's Avatar
I really need to know how to adjust for the injectors. I connected it and I don't see anywhere to do do it. At idle, the injector duty percentage is like everywhere....it's not good. Also, it idles KIND OF ok but when you give it gas and it comes back down it wants to die...i really am starting to aggree that it is due to the injectors being bigger than what the map was made for. ANyone think they can tell me how to input for the bigger injectors? Will the map jsut re calibrate after that (if i even can)?
Old Feb 25, 2008 | 10:35 PM
bruceg's Avatar
BUMPPPPpPpPp
Old Feb 26, 2008 | 03:35 PM
Ace83's Avatar
Ronin Scion
did you get another map from paul?
Old Feb 26, 2008 | 04:09 PM
bruceg's Avatar
no
