High-volume fuel pump = increased fuel pressure?
Old Oct 28, 2011 | 08:34 PM
PeArLwHiTe07tC's Avatar
lmao...i think someone needs to sticky all of fred's abbreviations!!!
Old Oct 28, 2011 | 11:14 PM
ScionFred's Avatar
Originally Posted by Syldrin
My wideband melted on my old exhaust so no I haven't noticed that.
It may be an XB-thing only. When the car was new it was so bad that it stalled sometimes. Later when I installed my UEGO I saw what was happening. 10:1 idle AFR after filling up, goes to 14.7 when I pull out and remains there afterward. Weird...
Originally Posted by crush02342002
btw fred if I can find my stock fpr you can have it to play around with.
Thanks Crush! I may take you up on that but first I need to see if I can even install a new pump and still keep the oem FPR.
Originally Posted by Carlanga
hey Fred right after I first installed the turbo, I went ahead and did a pump swap from stock to 255 walboro. Only thing I saw was a 6-8% drop in duty cycles and a tap bit richer in certain areas of the map. My guess because the extra flow and mainly the fuel delivery curve is different than the stock one. You should have no problems, just a tad richer than normal. Difference is I was able to change it with the fic.
Thanks Carlanga, that's great to hear. I'm stubbornly pursuing my no-piggy setup to see if I can take it just a little further. I'm pretty sure the only thing holding me at 6 psi is reduced fuel pressure during high-rpm boost. A bigger pump may be enough for 7psi.
Originally Posted by borderguy881
fred I swear brother I always get caught up trying to read your post you have spent many years with computing and forum lifestyles that you use such big abbriviation hell it took me months to realise what you meant by AFAIK.
Btw not going to mention my name here but I'm that guy you sold an aem fic to about 2 years ago and I also came by again to pick up your old cx turbo
Hey man! I remember you well. How's life treating you these days? Still got the boosted TC?
BTW, I have spent a lot of years on computer hardware forums. My previous hobby was building and overclocking PCs. AFAIC cars are more fun but IDK, YMMV.
Old Oct 28, 2011 | 11:36 PM
borderguy881's Avatar
Hey I'm doing well the car is boosted again on its second motor I am running a 60-1 turbo and I ran a 13.1 at 110 with a slipping clutch I recently joined the army a year ago and I'm stationed in korea right now and yes me and you have discussed your past hobby before that's why I brought up the years of computing
Old Oct 29, 2011 | 01:52 AM
thendawg's Avatar
Are you trying to stick with stock ECU because your trying to keep costs down, or because you like the fact that it runs smoothly? If its option 2, consider a return setup with a boost ref FPR - that way you keep stock fuel pressure while in vacuum, but under boost fuel pressure will increase linear to boost.
Old Oct 29, 2011 | 09:41 PM
ScionFred's Avatar
Glad to hear that you're doing well and congrats on a very good 1/4 ET. You can see my not-so-impressive ET in my sig. At my age remembering you is good, remembering everything we talked about, not very likely...
Option #2 and your suggestion is excellent. I'm heading in that direction and trying to decide whether to try the pump first or just do everything at once.
Old Nov 3, 2011 | 03:44 AM
DeAnzaJig's Avatar
Im guessing you could tell if you get bigger fuel trims. More fuel = more of a trim on stock ecu. Thats just my theory though.
Old Nov 3, 2011 | 04:11 AM
ScionFred's Avatar
Seems like sound theory to me. the only way it wouldn't show up in the trims is if FP remains the same in closed loop but differs during peak fuel flow in open loop when the stock pump pressure dips and the bigger pump doesn't. Either way I've decided not to pursue it. Too much time and money for ~20whp just so I can shave a couple tenths.
Old Nov 3, 2011 | 04:28 AM
DeAnzaJig's Avatar
what about a fuel return system? but that, too, is kind of a PITA
Old Nov 3, 2011 | 04:32 AM
DeAnzaJig's Avatar
also, you could get a water/meth kit. although you wouldnt have a very controlled way to tune it (if your still on stock ecu) but your intake temps drop incredibly low and you'd have a safer/richer mixture, creating more power at the same time
Old Nov 3, 2011 | 05:29 AM
ScionFred's Avatar
Those are good ideas but if I'm honest with myself the smartest thing I can do is leave everything as-is. I've met or exceeded all of my original goals for this project and even my weak A/T is holding up great. If I keep pushing I'll eventually find a limit and possibly a very expensive one.
Besides, I recently sold a WMI kit that I bought 2 years ago but never bothered to install. If I stay at 6 psi, I don't need to change anything and it's still cool to have a A/T Scion XB that can embarrass my buddies 08 R32
k1114
43
Mar 1, 2023 03:08 AM
JenK
Scion xD Drivetrain & Power
Dec 7, 2020 05:24 PM
BlackKnight
Sep 15, 2015 06:42 AM
Jonny5ive
Jun 12, 2015 08:06 PM
dgm458
Dec 7, 2014 05:59 PM
