Hodge Podge: Houston style
500f engine enamel (duplicolor i think). Iv used this paint on my ka24de build, worked like a charm. however on that build i didnt paint the head, just the block and vc.
nice to see u finally building your engine chris!
as far as paint goes dupli color makes a flame proof enamel that holds up to 1500. i used that on my vc after the normal 500 one peeled off due to excessive heat under the hood along the exhaust side. id do that so it doesnt look like poop a year later
all those colors are flat though..I want high gloss. my boy carlos is using 500f on his vc with great results..may be due to prep or maybe heat build up cause of manifold..not sure but it has worked for him so far. that is on his vc.
I think if I go 50psi again it will be on an APR
It is actually cheaper to go with the fullrace and an HX40. Mani is cheap, turbo is like 250 then 120 for a rebuild, problem is that I will need 2 WGs. Management would be a _____
