Hodge Podge: Houston style
just a few pics of kyle's car....see how many things you can spot that iv done to his engine bay...lmao (clue* there are 4 personal touches iv made to his car (no homo)
well if he ran the other breather on the valve cover to his catch can he would be seeing boost into the crankcase because his catchcan is routed to intake mani...... which isnt toop bright because then when in boost theres nothing sucking out the pressure in the crankcase, and thats where his valvecover to intake pipe comes to play but your right still allows oil in intake
the way i have mine setup is the pcv valve is venting to atmosphere i plugged the manifold and i ran the valv3e cover breather straight into the intake...
why?
1.i dont care bout blowby i rather that than have pressure in crank case..
2.i plugged the manifold because i was afraind that in boost the pcv might leak and let boost into crankcase
why?
ok chris start talking.... the pcv on back of valve cover is connected to a catch can and then ran to intake mani, and the part on can that connects to other breather on valve cover is plugged.
Way ive seen catch cans..
Either extra welded or drilled and tap ports on valve cover.
These goto catch can which filter oil out and reilve pressure.. Intake source now sucks air from here and puts it back into the intake now making sure no oil is being pumped into intake/turbo/intercooler.
lol and thats how it should be
From what ive understanded, crush made one hell of an expensive
http://www.gassavers.org/files/gassa..._catchcan4.jpg
Woulda done same thing..
Your not really stopping crank case pressure.. your just filtering it!?
ok guys before you start a really retarded argument on my thread take one look at a stock tc....look at the hose that goes to the pcv and look at what the other end of that line goes to...yep it goes to the intake manifold....forget the fact you see three lines and three tubes cause one of them is not used right this second and may not get used, it was just an idea that sounded good at the moment.
all thats happening here is a catch can is "spliced" inbetween the intake manifold and the valvecover, thats all. its there to catch a little oil and for looks.
Mike you got the idea, just not as cheesy...lol..pretty much all catch cans are based on that very same idea except for those that are just venting like ace83's. The main point of it is to keep oil from entering the intake stream, doing that will help to keep the valves cleaner longer and stave off excessive carbon buildup in the engine.
however what i really want to do is drill out the pcv thats on the valve cover and place a pcv inbetween the catch can and intake. doing this i hope will keep the pcv cleaner longer. enough oil build up and varnish will gum up the pcv and can make it stick open. your supposed to replace the pcv every so often anyway but this may help keep you from having to do it as often.
btw both of you have valid points...however cburgle you have to remember what the pcv is...its a one way valve, not a very reliable one but it is what it is. its ment to allow flow out of the vc but not in, for the most part it seals and prevents you from applying pressure to the head (and rest of the engine).
now if you were to totally seal up those two lines off the valve cover youll end up with alot of damn smoke and possible damage. what will happen is pressure from the rotating assymbly will find a way out and if turboed it wil raise oil pressure and yep you guessed it oil will leak past the seals at a rapid rate.
