how much boost???
im getting my zpi stage 3 block put in very soon and i need to know how much boost i can run before i need a new fuel pump and bigger injectors? right now i have the stock pump, and 550cc injectors.
zpi is really busy right now, and i call them enough as it is. is anyone out there running 15 psi on 550's and stock fuel pump, and if so how close are you to maxing out your injectors?
10 maaaaaaybe 12 psi with 550cc injectors depending on your compression ratio. The stock fuel pump is maxxed out at 550cc injectors 660s require a bigger pump, like a walboro.
Almost ever kit out there that makes 9-10 psi runs 550 and anyone running more boost runs bigger injectors, just look at zpi's stage 1.5 kit if you want proof, 12 psi 660's but the stage 1 runs 9-10psi with 550's
Originally Posted by malloynx
the mis-information in this post is out of control. i don't even know where to start.
BSFC mean anything to anyone?
crimson_sinn
Sep 25, 2015 09:41 PM
vi3tb0i09
Sep 23, 2015 08:32 PM
