I need a Dezod BlackBox!!!!
ok im stuck in a bad spot where im gonna have to use the emanage Blue for a while with my build to tune it and i hate it! one thing that will make me happier is a blackbox so i can tune partial throttle! where can i get one ? anyone selling any?
pressure sensor and black box are completely different
black box controls closed loop o2 (aka partial throttle)
pressure sensor lets the emanage tune off PSI not the MAF sensor (still full throttle)
I also have a black box LMK
Originally Posted by RichTc
What is the difference between the blue and the ultimate in terms of tuning partial throttle? I thought they had similar functionality regarding the ability to tune partial throttle?
have you hooked it already man? how's it running? be sure to check if the tune is loaded..
and yeah greddy pressure sensor is different from blackbox.. although both uses/tunes through boost/manifold pressure, the pressure sensor is to be used with the emanage as an option so you will be able to tune based on boost pressure (preferably) still control no full control on partial throttle because the O2 sensor (closed loop) alters fuel to lean it out.. BB does is to keep the tune from leaning while on closed loop
I'm am a little nervous about splicing into the wiring harness to hook it up though. Does anyone know where I can find how the pin's are numbered on the stock harness (I think the directions indicates a pin number).
yes dezod tech notes
http://www.dezod.com/tech_notes.cfm
all infos are in here, ecu pin out, install manual even the basemap if its not loaded
Sweet. I'm surprised I hadn't found that section of their website before.
Last question on thi, Did you splice it into the plug and play emanage harness or into the ecu harness? I would think the ECU harness
Thanks!
Thanks!
Yeah. That's my biggest concern with splicing into the ECU (splicing the wrong wires).
I'll get a buddy to do it with my to double check me.
Probably is a good idea to do the Plug and play though, cause if I screw it up bad, it will be a lot cheaper to replace than the ECU harness.
