im missing parts from my s/c what should i do
ok so i went to toyota today to ask them for the install and the guy told me i was missing parts such as the oil pan fuel lines some vaccume hoses and other things..i tried to call the guy who sold me the kit and hes being shady. he shut off his phone and isnt on aim nomore...i paid thru paypal so what should i do?
this is what he gave me....what do i need because he told me that i can use my stock oil pan or something and he sed the oil feed line i can use the stock? or something like that and for the oil pan i can weld something onto it also i think im missing the ecm map module(what do i do about that) if you guys think im miss some other stuff please let me know
I would buy a oil pan the hard line oil return doesn't have any play in it so if get yours welded it would have to line up perfectly. Also just so you know the oil return line for the s/c is 1/2" I belive a -8 and the standard oil return for a turbo is -10 3/4"
It looks like he didn't give you the bottom part of the airbox either. As for the ecu if he didn't give it to you, then you have to get a flash tool which is a one shot deal so if he gave you the flash tool that came with the kit then chances are it won't work because he has already used it.
Also with the ECU reflash module.. if that is missing.. it is esential for final installation of the supercharger for the 06 tC.. my kit was missing that.. surprisingly the only thing missing from the kit.. I got lucky though.. the kit was won at a car show.. i contacted corporate that donated the S/C and they authorized the dealer to order the Reflash module and they would pay for it..
The 100 buck crank bolt is nothing compared to the 400 bucks for the ECU reflash module... And it is vin coded once it is used, so the seller cannot just give you the one he originally had.. I had a friend that had one installed and had him rush his module to the dealer.. dealer tried it.. didn't work.. found out from TRD that is can only be used on the car it was coded to or something like that.
unless your gonna run a ECu piggyback.. you will need it with the superchager.. with out the reflash your tc will run bad.. the computer will try to dump too much fuel because of the extra forced air that it is receiving and you will have denotation.... just because you have the 12psi pulley you can run without the reflash.. they guy doesnt know what he is talking about
i am the one that sold him the supercharger kit! and i told him a few parts were gonna miss unless he sends me his parts to swap out i sent him the map module and the cps extension wire also the onl thing he didnt get is the oil pan, vacuum hoses (5 bucks at auto parts store) the thermostat and the radiator hose which like i said i would give him oh and my ecu! but then again the reflash wont mean crap cause he has the AEM so he will tune it off with that since i gave him te 12psi pulley. and the crank bolt? for what? that bolt wont stop the supercharger from working to be honest i think that bolt ws a waste. but like i told him sends me his stock parts that is missing and i will send him mines i have no problem on that. and as for the stock airbow of the trd kit he said he didnt want it cause hes gonna use his intake. and as far as the oil pan you can tap into that with no problem at all. like i told him there is no need to take it to the dealer cause they are gonna over price badly. it took me about an hour or so to take off the supercharger its just 2 bolts by the starter for the supercharger bracket and 3 bolts by the pulley side and thats all and connect the charge pipes and do the oil lines. but whatever and as far as tuning you can tune it with the AEM no need for reflash.
^ dealt with this guy before he is good person to deal with.
got my BPV like we dealt.
crank bolt is for what actually ?
what is his function in the supercharger kit ? cause in my opinion crank is wayyy far from the supercharger.
i guess it doesn't stop the charger from working, maybe i am wrong.
hope everything works out man.
you can always contact TRD sparks, good customer service.
ECU re flash module? What is that? Is there a way to tell if your ECU was reflashed or not ffor the SC? Do they mark the ECU? Put a sticker on it? Part #? Anything?
Or do I have to take it to a dealer and ask?
Thanks, J~
Thanks, J~
Thanks, J~
Thanks, J~
^ nahh man i am gonna install the charger this weekend if my PLUGS come in. LOL
couldn't find any around here so i had some friend in the states bring me 8 Plugs.
i don't think i will get tired of that woosh... LOL it's just what i want.
HEHEHE
HEHEHE
The crank bolt is for the extra stress that running a belt to the compressor causes, if it wasn't needed trd wouldn't have included it in the kit. If the stock crank bolt breaks off in the crank shaft you would have a very big problem to deal with.
