J3st3r's Setup(s)
Hey Jester, I know you no longer have the Wilwood BBK, however. Can you clarify whether the BBK works with the stock wheels alone? Kanchi and a few others say it does not work for their kits but you said it works for yours.
https://www.scionlife.com/forums/sho...&postcount=100
The goal at this point is 400whp on the Mustang dyno, and we should be there once we get the rev limiter bumped up a few hundred rpms, at the same boost level. This setup is what we will be taking to the Scion Exposed event next month at Oreilly Park to see what it will do on the track. After that we will probably do some "bragging" dyno pulls, with increased boost, maybe an E85 map, but the overall goal is to have this at 400whp since this will not be a drag car, or dedicated race car at this point really no reason to have it over that
Mustang uncorrected dyno. Stock motor. 14-15 psi. E85
Was going for 360 ish before fuel regulator blew apart
You were praising them for 400whp on 20psi with built motor and 900cc injectors...on Dyno Dynamics
We are at 377whp on 17psi with built motor and 550cc injectors...on Mustang Dyno....and you are giving me the business.....just curious
Here is one of the earlier runs
Tomorrow it is going down to the Dynojet so that we can see how those numbers compare to the Mustang Dyno numbers
Interesting because on this thread here https://www.scionlife.com/forums/sho...d.php?t=175098
They did it on a 300.00 AEM fic with 91 octane..
I have followed your build.. And i figured you would shoot for more then 400. Ptuning had no issue puttin 550whp down..
Im not downing you bro.. Maybe you took wrong way.. Sick car. Sick build! But id like to see u do 450 here. 500 dynojet. Then find what boost level works for you at the track!
The other issue we would have at those numbers is my block is not sleeved....
Have no idea, all I can tell you is that I tried/tested them with my setup, and everything worked fine, maybe the S7's are different offset than stock
Well....still here...thought I would provide and update on the "Unicorn"
Last year before the exposed event...we had a slight....um...ok major melt down...literally with the motor
So we took a step back and really evaluated the whole setup
So we decided to make some changes in the setup:
1) Ditched the Hydra for what we consider a more reliable and proven solution....Emanage Ultimate
2) Got a new block and started from scratch
-Blocked Bored .020+
-CP Pistons
-ARP Fastners(Head & Mains)
-Head Completely Gone Through
3) Buttoned up misc things
-Defi Oil Pressure Gauge
-Dezod Braided Brake Lines
-Speed Bleeders
-Ditched CC Short Shifter in Favor of TRD Shifter
-ES Master Bushing set
-New Lugs
-New Weighted Shift ****
-Speed Source Motor Mounts
-CP Pistons
-Speed Bleeders
-New Lugs
Motor was assembled today!
Since the new lower block was from an 08-09 it had to be clearanced so that the ARP mains would clear
Comparison of the 05/06 to 08/09 lower block
Still debating on the e85 deal however the gas station less than a mile from our house now sells it so the option is definitely tempting
