k1 rod question, which way to front?
Old Mar 19, 2010 | 10:23 PM
gompka's Avatar
Default k1 rod question, which way to front?
When installing K1 rods which side of the rod goes toward the front of the engine? Which side are the bearing tangs supposed to be on the intake side or the exhaust side?
Old Mar 20, 2010 | 01:18 AM
ScionCREW's Avatar
normally bearing tangs face to the exhaust side. check with K1 because it verys with manufacture.
Old Mar 20, 2010 | 01:25 AM
brett561tc's Avatar
is this art or leslie?
Old Mar 20, 2010 | 02:33 AM
ScionCREW's Avatar
art
Old Mar 20, 2010 | 03:12 AM
brett561tc's Avatar
what type of coilovers, and what spring rate do you run in your 9 sec turbo tc?
Old Mar 20, 2010 | 03:32 AM
ScionCREW's Avatar
progress technology coil overs
http://www.progressauto.com/view.jus...over_photo.JPG
changed the rear springs to 1000 lbs springs to minumize it from squatting
Old Mar 20, 2010 | 05:10 AM
brett561tc's Avatar
thanks bro.
Old Mar 20, 2010 | 05:13 AM
brett561tc's Avatar
also, what kind of 60' times do cut?
Old Mar 20, 2010 | 05:30 PM
ScionCREW's Avatar
we averaged 1.50 with a best of a 1.40 60'
Old Mar 20, 2010 | 08:36 PM
brett561tc's Avatar
dayum!!!! how did you guys have your 2-step set up? im leaving at 5800rpms, between 9-11 psi, and im averaging a 1.80-1.84 60' with no lsd.
Old Mar 21, 2010 | 03:31 AM
ScionCREW's Avatar
you should look in to a LSD it will help on your 60'. mybe try dropping you 2step alittle. At 5800 is your car bogging or blowing the tires away?
Old Mar 21, 2010 | 03:32 AM
ScionCREW's Avatar
Old Mar 21, 2010 | 03:42 AM
brett561tc's Avatar
click the youtube link in my sig.
Old Mar 21, 2010 | 03:59 AM
ScionCREW's Avatar
good run man.. what EMS are you running?
Old Mar 21, 2010 | 04:00 AM
brett561tc's Avatar
aem
Old Mar 21, 2010 | 04:01 AM
ScionCREW's Avatar
can you send me a log of ur run? i would like to see the car is doing
Old Mar 21, 2010 | 04:03 AM
ScionCREW's Avatar
is it a EMS or FIC
Old Mar 21, 2010 | 04:04 AM
brett561tc's Avatar
ems
Old Mar 21, 2010 | 04:05 AM
brett561tc's Avatar
i dont think its still on there. i'll have to go to the track again soon and log it.
Old Mar 21, 2010 | 04:39 AM
ScionCREW's Avatar
that run sounded like you bogged alittle
TotalChaos
13
Feb 4, 2015 10:24 PM
torranosaurus
Jan 28, 2015 04:53 AM
Godfryness
Jan 2, 2015 11:18 PM
lunchbx05
Dec 29, 2014 07:53 PM
BlueBox
9
Sep 25, 2003 04:36 PM
