Louder than usual valve tap
everything you posted in the first post sounds perfectly fine to me...but I'd go with 5w20...no reason to change oil weight, as long as it's full synth.
but yeah, once you get yoru pressure sensor tuned properly, I'd ditch the black box.
^^ thanks phil, mike... cars running fine just seems super loud to me.. im going to compare it to satoman44's car tonight and see if its just my mind playing tricks on me..
but phil, even if i tune with the preessure sensor i still wont be able to tune partial throttle.. i do agree though.. its seems wierd that it all started right when i installed that.. i also did put in my two step colder plugs without adjusting my tune.. could that affect my idle real bad?? now that i think about it... it could.. right?? thanks guys!
^^ i dont know how loud is your tap java, i guess its really loud coz you have a turbo tc that you compared it with.. but i know the tap has got louder with mine but yours might be louder.. how bout video clips?
plugs will effect idle...i'm not saying the black box is bad...I'm just saying there are plenty of cars on the greddy, and I'm sure there is a reason why dezod isn't selling them anymore...
yeah i guess your right even though they said they stopped selling the black box because the FIC becamse the piggy back of choice.. yeah once i re tune with the pressure sensro hopefully my idle afrs will be more steady..
you can adjust partial throttle with the emanage. My wifes car has has the Greddy kit (for now) w/ a 3" intake and a 2.5" adapter and 650 injectors, and her car runs perfect, and idles perfect. we had to take out a bit of fuel at idle for it to idle smooth, and we only tuned off the maf, not a pressure sensor. i really think tou need to visit the dyno again with out the black box, and make a few adjustments to the emanage. i dont see any reason to have the black box and the emanage hooked up at the same time.
ok so i did the "screw driver test" to see if it was my lifters or valves and none seem any louder than the other so my conclusion is blown head gasket, exhaust leak at either the mani to the turbine or my exhaust gasket itself. will rip the car apart this weekend to trouble shoot.
SloTC1
Aug 16, 2018 02:45 PM
vi3tb0i09
Sep 23, 2015 08:32 PM
