M=tuned Turbo kit : little update for now
Old 03-17-2009, 04:29 AM
weezyfbayba's Avatar
any reason why i couldint get the kit tuned?
weezyfbayba is offline
Old 03-17-2009, 04:45 AM
TurboToyotas's Avatar
on a side note:
If someone purchased a used 05-06 kit and they have a 07-08 I know where you can get the correct intake pipe with the right maf flange. Or vice versa for that matter.
regards-
Todd
TurboToyotas is offline
Old 03-17-2009, 05:40 AM
OhioScions
OC3RULZ's Avatar
Like Todd said, the INtake pipe is shaped differently and the MAF is wrong. the way the air moves over the MAF totally makes it flip out.
You will need the INtake pipe from an 07-08 to make the rest of the kit work. PM Todd
OC3RULZ is offline
Old 03-17-2009, 09:23 AM
Ronin Scion
Ace83's Avatar
Originally Posted by weezyfbayba
oh ok then guess i just have so save up for the 2.1 kit ftw lol but why wouldint tuning work if it would fit?
as mentioned its just because of a different maf sensor flange... you can either get that maf adapter or get an intake pipe with the 07 up maf sensor flange as suggested above.. all the rest you're all good
Ace83 is offline
Old 03-17-2009, 10:27 AM
davedavetC's Avatar
Originally Posted by TurboToyotas
on a side note:
regards-
Todd
good man good man
davedavetC is offline
Old 03-17-2009, 01:13 PM
ok so before i drive an hour to go meet up with this guy to look at his kit can it be tuned with no problem's? if i got the maf pipeing swaped? and tod thanks alot bro and don't worry im still buying that 2.1 kit just rather have it in full cash first halfway there tho my g/f is buying me this 1,500 kit
Old 03-17-2009, 01:20 PM
jbae1221's Avatar
such a debate.... i'm so torn... turbo toyotas or dezod . i've been reading all these dang posts and just cant' decide
jbae1221 is offline
Old 03-17-2009, 01:24 PM
im not knocking dezod they make awsome kit's just im in love with the TT kit's thats just me but id really like someone to say the kit can be tuned with no problems just gotta switch that maf pipeing in what i already have someone swaping me pipe's
Old 03-17-2009, 01:26 PM
Ronin Scion
Ace83's Avatar
it can be tuned as long as you have the right intake and an engine management
Ace83 is offline
Old 03-17-2009, 01:27 PM
well i just got call into fing work but im going tog et out early so go look at the kit anything i should look for in the turbo like how can i tell if it has shaft play by moveing the flange up and down or side to side? please leave me as much 411 as possible thx all
Old 03-17-2009, 03:49 PM
OhioScions
OC3RULZ's Avatar
grab the compressor wheel shaft nut and pull in/push out. see how much it moves. you get more than lets say 1/4" of movement the turbo is gonna die soon. spin it with your fingers as well, too see if it hits the housing, you will be able to see this as well. And make usre that there is no OIL in the housings.
Other than that you are good.
OC3RULZ is offline
Old 03-17-2009, 04:36 PM
crush02342002's Avatar
check to see what engine managment system comes with it....if its the unichip it will not plug into an 07-09 tc...thats not to say that it couldnt be hard wired but i really couldnt say for sure...also could be an adapter for it but iv never heard of one....
now if its anyother managment (AEMfic, greddy blue, greddy ultimate, ect) you will need to order a pnp harness or have some one hardwire it in...its alot easier to get a pnp harness though...they can be found @ boomslang.com or from just about any vendor on here...i think most sell the boomslang harness. they go for about 300-350.
crush02342002 is offline
Old 03-17-2009, 04:41 PM
OhioScions
OC3RULZ's Avatar
^ good call! I forgot about the Unichip that came with Turbonetics kits
OC3RULZ is offline
Old 03-17-2009, 05:03 PM
i don't think he is includeing any fuel management with it i was going to buy the AEM fi/c for it with 550cc injector's but the pnp harness wouldint come with the aem fi/c if i bought it? but he is includeing the a pillar gauge pod and the gauge's but im about to leave to go check it out if i like what i see ill get it at the end of this month and like i said ive already got someone willing to swap me maf sensor pipeings from a 07/08 kit so that problem is solved also i already have a 9.5lb fidanza flywheel is it 2 light for turbo? im going to be getting a stage 3 clutch also before i install the kit
Old 03-17-2009, 05:06 PM
Ronin Scion
Ace83's Avatar
sounds good.. you would have to buy the pnp harness separate, look around here you might find someone selling rather than brand new. 9.5 is kinda aggressive but it all depends on you
Ace83 is offline
Old 03-17-2009, 05:10 PM
i just want a clutch and flywheel setup that's going to grab and not mess around lol but i already have it so i guess i have to use it should i use stage 2 clutch or stage 3 im going with a CC clutch i was going to get stage 2 before i decided to go FI should i step up to stage 3 ?
Old 03-17-2009, 05:20 PM
ok so the list as of now what id need is
AEM fi/c & pnp harness
clutch....
thx all you guys have been a real big help im heading out now to look at the kit i will try and take pictures and post them up here thanks alot all
Old 03-17-2009, 05:41 PM
Ronin Scion
Ace83's Avatar
you might still need to shop few misc install parts, depends on what your kit comes with.. but as for clutch im sure you would be safe with stage 3 unless you are wanting more serious power, you dont really need the flywheel but it will help get to boost faster
Ace83 is offline
Old 03-17-2009, 10:09 PM
haha this kit was a joke there wasint even the pipeing for the maf he had some screen with a clamp around the turbo i was going tot ake pictures but i just laughed and left lmao looks like ill be getting the 2.1 kit then!
Old 03-17-2009, 10:18 PM
yikes......thank god you wher able to see it first before buying it....lol
dont worry your not the first to take out a loan in order to get a turbo kit.....i did just that...lol
i was looking for some ways to boost my credit and establish myself with a couple of banks....next thing i know iv got a check for five grand in my hand and no idea what to do with it........Turbo poped into my head....rest is history...lmfao
Quick Reply: M=tuned Turbo kit : little update for now
