MAF plate?
anyone have a link to where i can pick up a maf plate? i want to make a blow through set up on my kit but i cant find a plate just a 3" housing through ATPturbo.com
You're in luck, I just recently had to do the same thing.
http://www.kstech.biz/servlet/the-Bl...MAF/Categories
KSTech also has an Ebay store. Look what K&N has hidden under "air filter accessories":
http://www.knfilters.com/filteraccess.htm
Make sure you get the correct flange. The MAF sensor changed in 06 or 07.
It's a steal with free shipping. One caveat tho... the one I bought (08262) is contoured for 3" tube. That worked perfectly for me but it won't fit as well on 2.5" tube. Nothing a good welder can't fix.
I fabbed a new 3" draw-thru intake instead. I wanted to do blow-thru but the X1 can't compensate for non-oem MAF tube sizes. TCs should stick with 2.5" and XBs should stick with 3". At least that's true if you want the ECU reading accurate load (a must for AT). With a MT you could get away with it.
Seems like quite a large short coming for ATs. I'm running a modified Turbonetics kit which comes with a 3" charge pipe (MT). I've been considering a blow through set up for a little while since IATs affect the X1 more than MAP based EMS's. I had a custom heat shield fabricated which has helped a reasonable amount, and I'm currently waiting for a vented hood to better improve IATs. I'm still entertaining the idea of blow through, but want to see how everything pans out with the hood and cleaning up the tune and idle/low speeds.
I have the same IAT and heat-soak problems here. Crusing at 60mph my IAT is within a few degrees of ambient but in stop n' go traffic or extended idling, IAT climbs upwards of 140F on a 90F day which oddly causes a lean condition. I'm planning to make a heat shield for the filter and considering powder-coating my pipes for some thermal insulation. For now all I've done was to remove the rear hood gasket. This seems to have helped a little by letting hot air escape at slow speeds and IMO looks a lot better than hood risers. In fact I don't understand why anyone would install hood risers when they could simply pull a rubber gasket off to accomplish the same thing for free in 1 minute.
Anyway, I think a 2.5" blow-thru MAF would work very well for a TC with the X1. Have you had many problems tuning the X1 for a 3" MAF tube considering that the oem MAF tube is only 2.5"? It seems to me that your ECU should be seeing reduced airflow and load which would make it neccesary to add fuel and retard timing. It would wreak havoc on a AT.
If I had known the X1 lacked that capability I never would have bought it. Instead I was told that all I had to do was change the MafID. No one seemed to know at the time, not even APR. It took me a lot of time to figure out exactly what MafID and MafAdj affect and how they interact with Inj offset sizing and InjAdj. There's some wierdness in the APR programming too that had me pulling my hair out at times. E.g., the Tacoma has a 3" MAF ID stock but every APR tune sets MafID to 65mm. I had a 66mm Maf tube but had to set MafID to 75mm to get the most accurate MAF/load match between ECU and X1. Now with a 3" MAF tube I'm finding that I need to set MafID even higher. With MafID set to 75mm I was able to get my ECU controlled fuel trims within 4% +/- and it runs great. However when the X1 takes over it immediately has to add 20% (+/- 5%) fuel to acheive target AFRs. My max MAF is 175 g/s ECU but only 142 g/s X1 at 75 MafID. As I raise MafID, X1 MAF increases and my next step is to find the MafID that matches the ECU. If this works as I think it will, I should be within 5-10% on fuel adaptives before I even touch the InjAdj table. We'll see...
syldrin i see your from lakewood....i live in lakewood as well and i have an 05-05 maf plate just lying around you can have. if you want it pm me your info and ill give ya a call.
The only issue I really have is the high IATs leaning me out when I'm decelerating or at idle. I once tried to connect some ducting to extend the filter into the fender well but that caused crazy turbulence and crapped on throttle control, so I took that off haha. I fixed a handful of small exhaust and other leaks ie wastegate gaskets, MAF adapter plate, stripped T-bolt clamp, and donut gasket between d-pipe/s-pipe; so I'm waiting for my vented hood to come in so I can head back to Dezod and have Paul clean things up now that IATs and leaks won't cause problems.
I don't want to space my MAF sensor out of the tube too far but I'm planning to try some thin plastic or nylon washers between the AL MAF flange and the metal MAF mounting bracket to provide a little thermal insulation. I'm also planning to look for some nylon machine screws to use in place of steel. Some form of heat sleeving or thermal wrap is also on the to-do list. I'll let you know how it works out.
If the ECU thinks that IAT is 140F but true IAT is 120F, the denser air charge would result in a lean AFR. If the true IAT were hotter than measured by the IAT, the AFR should be richer.
Unless I'm missing something else.
I have quite a few for the 05-06. Made a batch and had a bunch leftover. They are same as STi/WRX so was using them for both setups. Email me at sales@6distribution.com if you want one. I'm sure I can sell them for less than the going rate on ebay.
i need to change that gingles. thank you but i actually live in Vista, California now. i left for bootcamp back in sep of 09 and im stationed out here now.
