MAF plate?
Old Sep 4, 2010 | 05:36 PM
MrC_Ptuning's Avatar
If there's a demand for it, we may be able to sell our MAF flange used on our spec-ss/spec-rs turbo kit separately. Here's the MAF flange setup used in the blow-thru setup for our spec-ss turbo kit's upper intercooler piping. The MAF flange setup is a modular two piece design that allows us to use the same base flange on all our I/C piping regardless if it's for the first or second gen MAF sensor (large or small). We simply swap out the top flange to mount either of the two MAF sensors. It's sealed by a high temp o-ring. This would only be ideal for someone building their own i/c piping that would like to have it work on tC from '05-'10. Unfortunately it's going to cost quite a bit more than what's available out there as a single weld flange.
Here's a few pics.
MrC
Old Sep 4, 2010 | 06:46 PM
gingles's Avatar
Originally Posted by ScionFred
If I'm not mistaken, lowering the actual IAT after the IAT sensor would only make the problem worse. The problem appears to be that the IAT sensor is reading higher IAT than the actual IAT entering the combustion chamber. I'm not sure how else to explain the lean fuel condition.
If the ECU thinks that IAT is 140F but true IAT is 120F, the denser air charge would result in a lean AFR. If the true IAT were hotter than measured by the IAT, the AFR should be richer.
Unless I'm missing something else.
i keep forgetting people are still doing pull through maf's. so if you had a blow through then the intercooler in fact would help.
Old Sep 4, 2010 | 08:05 PM
ScionFred's Avatar
Yeah, a better IC would help reduce actual IAT but I think the problem I'm having is the MAF/IAT getting heat-soaked and reading higher than actual IAT at idle and slow speeds.
Old Sep 5, 2010 | 05:36 PM
Syldrin's Avatar
approx how far from the bov should the maf be placed?
Old Sep 5, 2010 | 05:38 PM
Syldrin's Avatar
MRC - i dont think there would be enough demad for the ptuning flange. not many people consider a blow through maf set up unless they want the ptuning kit. and with the ability to get the proper flange for 15 - 30 bucks i dont see ptuning making that much money off of the offer
Old Sep 5, 2010 | 06:33 PM
ScionFred's Avatar
As far as possible while maintaining as much straight pipe before the MAF as possible. Ideally you also want some straight pipe after the MAF too but before it is far more important. You don't want bends or couplers too close to the metering side of the MAF.
Can you post some pics of your setup?
Old Sep 6, 2010 | 04:28 AM
Syldrin's Avatar
i can take a pick of the upper ic pipe tomorrow.
Old Sep 6, 2010 | 05:06 AM
XPRTc's Avatar
I recall Paul telling me that the MAF should be at least 6 inches away from the BOV and clear of bends near by, but at the same time as close to the throttle body for accurate readings without going against the aforementioned.
Darrenohooligan
Sep 26, 2015 07:21 AM
Mjdavis1994
Sep 21, 2015 04:42 AM
Gigs
Sep 15, 2015 03:54 AM
Subaru86
Sep 14, 2015 12:43 PM
Subaru86
Jul 31, 2015 04:33 AM
