maf sensor placement
Old May 2, 2009 | 04:18 PM
gompka's Avatar
Default maf sensor placement
I have been playing around with my maf sensor placement and have run into problems I wanted to ask you guys if anyone knows if the placement is an issue. For placement, image this, the stock sensor is right after the air filter and if you think about an x/y axis coordinate graph the maf is on the x axis and its pointing down. Now i moved my intake piping straight down under the battery tray and i put my maf into the side of the piping in a way that it is put into the side of the intake pipe, so its on the y axis and its pointing toward the negative part of the x-axis. Anyway when i changed the placement like this car runs like ____. Any ideas? I'm guessing the maf position is the culprit.
Old May 2, 2009 | 10:05 PM
NVMyTc's Avatar
are you sure you didn't create a leak around the MAF when you changed the position?
Old May 3, 2009 | 12:34 AM
aen's Avatar
aen
have you tried turning it around?
Old May 3, 2009 | 03:02 AM
OuterHeaven's Avatar
Well mine is upside down and it runs perfect. I would make sure it is pointing the right way though like AEN said.
Old May 3, 2009 | 06:15 AM
gompka's Avatar
i'll try turning it around next time i get a chance and I'll let you know if that fixes the problem. Thanks
Old May 4, 2009 | 01:32 AM
jjos1's Avatar
I noticed when I had my intake below the battery the intake pipe was very short and the car would always stall and run bad probably because of the lenght, I tried rec the blow off valve and still had the same problem. Here are some pics of what mine looked like before I moved it and put a fmic on
Old May 4, 2009 | 01:35 AM
gompka's Avatar
yes i was experiencing the same problem and my intake piping was only like 6" when i routed it below the battery like you. I'll try to extend it and see what happens, I need to get some silicon elbows.
Old May 4, 2009 | 01:43 AM
jjos1's Avatar
What size is it 2.5" or 3" running a 3" intake is going to cause you to run lean.
Old May 4, 2009 | 01:45 AM
gompka's Avatar
stock 2.5" size, i'm going to try to put a 90 degree elbow on it and put the filter behind the foglight hole on the driver side, see if that helps.
MeDizzy
Oct 8, 2015 03:31 PM
prescottn
Sep 22, 2015 01:30 PM
gqdabien
Sep 17, 2015 09:23 PM
Gigs
Sep 15, 2015 03:54 AM
Topfueltom69
Sep 6, 2015 05:25 PM
