Max safe s/c psi - 9.5lbs? 10.5lbs? 12lbs?
Originally Posted by BionicJuic3
How big of a difference would it be from 9.5 to 10.5psi? Is the installation on the RippMods Water/Meth Injection difficult?
Its not a hard install ...but just a bunch of small things that built up time. It made it easier for them to pick the car up on the lift .....that way they were looking directly at where they were mounting the pump ...etc etc.
Originally Posted by krdshrk
Why not go straight to a 12lb pulley like Karl did? Or did Perry say not to?
My s/c warranty is now void after this visit since aftermarket parts and TRD dont mix. Its honestly bull because everybody and their brother knows what I have is not going to be the "cause" of any s/c problems. BUT - TRD said that they will pay for the new shaft and I will pick up the few hours labor it took to put the charger back in. For now I am happy but who knows for how long. If anything big goes wrong w/ my charger is comming off and im throwing a turbo on, fixing the charger, and selling it for a good price. Simple as that.
Originally Posted by draxcaliber
what if you put on the smallest drive pulley with a larger crank pully? could you be able to increase boost past 14 psi then build it. then you could have higher boost.
I gotta question about the tune? Are you actually planning on getting it dyno tuned?or just getting the TRD reflash? Im curious because Im thinking about the supercharger and if I get it i want to run the 9.5 pulley.
thats what Im going to be doing, im going to get the 9.5 and have it tuned with my emanage ultimate. My only fear is when going to 9.5 causing the seals to leak. As far as I know, there isnt a rebuild kit for the S/C but garage1217 did take it apart. Is there anyone running the 9.5 for quite a while and not experienced oil leaking from the S/C?
I just bought a 10.5 pulley and should get it in another 3weeks or so. People are running 12lbs and have been free of problems. 9.5 is safe and NST did a test with a 10lb setup and it was "iffy" ...meaning that you can use the TRD tune with the 10lb but you shouldn't. My 10.5 with the eman ult is gonna give some sweet numbers. I know a guy that is getting his 9.5lb tuned w/ the eman. He will have methanol and a header back setup. I cant wait till I see the results. I should know by wednesday night if anybody is interested.
Originally Posted by equinox2355
Well I mean as far as the life of the seals of the s/c and the s/c leaking.
Originally Posted by TexazBaller06
so basically i could get the TRD reflash with the supercharger and install the 9.5lb pulley with no issues??
I have the methanol kit with my 9.5pulley because I was preparing to get tuned. If you are going to stay w/ the 9.5 pulley dont bother with methanol ....you will only get a few hp off it. When you get tuned you can gain like 20hp from the methanol and also keep the car safer
