Mechanical boost gauge vs electrical
Old Mar 29, 2008 | 05:52 PM
rickelch's Avatar
Default Mechanical boost gauge vs electrical
I tried the search but was unable to find this topic. I am install a TRD s/c soon and was looking for opinions on what type of gauge to use. I want to mount it on the steering column, but did not know the benefits of mecahnical or electrical. Thanks.
Old Mar 29, 2008 | 06:05 PM
Scott8's Avatar
mechanical uses a long piece of tube to connect to the vac source with a t-fitting.
the electric uses a relay that you connect to your vac source. Both are pretty accurate if you run them correctly
Old Mar 29, 2008 | 07:52 PM
kikcaffine's Avatar
As long as you have a digital screen for the boost gauge your good.
Old Mar 29, 2008 | 09:03 PM
Kydog's Avatar
What scott said. Either one you have to hook up a couple electrical wires just with the electrical gauge you have to hook up a couple more.
Just dont get too cheap of a gauge. On cheap mechanical gauges some of them will "jump" when you hit a bump in the road. Also I have compared digital readout gauges against what ecus are reading and the digital is always off. So I wouldnt recommend a digital unless you want to spend a bunch of money on the AEM.
My .02
Old Mar 30, 2008 | 12:00 AM
Scoobasteve4132's Avatar
I think it's worth the $$$ going w/ the AEM Tru-boost gauge/controller, as it's just that, a gauge and a controller... It allows you to program two different settings to it that are controllable from the gauge... there are two buttons on the face of the gauge for the settings...
Old Mar 31, 2008 | 01:20 PM
BLUEMEANIE's Avatar
Team Hamster
^ S/C won't need the tru-boost gauge/controller.
Just get the regular AEM boost gauge, the 35lb one.
k1114
43
Mar 1, 2023 03:08 AM
BlackKnight
Sep 15, 2015 06:42 AM
ShawnMcc
Jul 11, 2015 11:07 PM
my06tc
Jun 25, 2015 12:18 AM
mattjk
121
Dec 22, 2004 10:49 AM
