new problem!!
Its not your map thats the issue... People switch from pull through to blow through all the time. And they can drive the car.. May be a little rich up top.. but not 10 afr at idle.
You either,
A: didint seal the ic pipe to TB right
B: Have Maf backwards
C:Left the vacume line from valve cover to intake manifold unhooked
D: Something really fin crazy
You either,
he either,
i know for a fact the maf is not backwords, its pointing in the exact same posistion as ptunnings blowthru, with the harness on the bottom, and its almost in the exact same spot
i'll have to check again for vac leaks, just got my dezod vac block in so i'll go over all my lines
lol hopefully u didnt run th crankcase cover to the vac block...
