Officially boosted on 8.30.13
Hey everyone,
I just got the tC back, and the turbo kit is finally up and running. It's a slightly modified turbonetics kit running a 50 trim .63 a/r t3t4 turbo and 550cc deatschwerks injectors. It's also being controlled with an AEM FIC instead of the standard Unichip. Right now its running off of a base map, so I won't have any dyno numbers until next Monday when it gets tuned but I'll be sure to post them up as soon as I do.
Thanks everybody, the installation was done by a very good friend who owns a performance shop in the area. I figured it was better to let a professional handle it; especially since there was some custom fabrication that had to be done. The base map that I have is meant for different size injectors, so it was enough to get it on the flatbed but I definitely can't drive it yet. Once it's tuned I'll be sure to get some videos and dyno numbers up
Hopefully you shouldn't have any trouble achieving those numbers at 10 psi. That's right what I'm going for too. It's actually an eBay grill that I bought a while back. The top fit perfectly, but I could never get the bottom to snap in (thankfully that's not a problem now). The only thing I don't love about it is the fact that it's a gloss black instead of a flat black, but other than that i haven't had any complaints. Here's the link: http://www.ebay.com/itm/180858219875...84.m1439.l2649
Awesome bro! Thanks! I wonder if this would fit with the intercooler? I am probably going to have to paint some chicken wire or something and rivet it in otherwise. I do a lot of highway commuting and there are bugs and rocks galore here in Michigan. I wish the front of my car was still as nice as yours ;) I guess thats what happens after 120k miles lol
Quick question for everyone, the car is going in for its tune on Monday and I still have almost 3/4 of a tank of regular in the car. I need to drain the tank and fill it with premium beforehand, but I don't have any experience doing this. I image it's impossible to siphon it out, but does anyone have any other ideas? I'm thinking of just disconnecting the fuel line going to the injectors and priming the fuel pump over and over again until it all drains out. I've tried searching but apparently everything thinks anyone who is trying to siphon a gas tank is up to no good...
under the back seat pull the cover of to the fuel pump and the the plug that feeds the pump has 2 sections one of the sections has two leads jut tap them wit a battery until the fuel is out. if the polarity is backwards u will know nothing comes out the fuel line in the front and don't worry u will not mess up the pump if it backward at first its just a motor that pumps which ever way its fed from power.
