OG's Still around?
Old 08-10-2014, 02:25 PM
  #101
MillerRS1's Avatar
Still rocking my 05.
Always wanted to go for bigger numbers.
Bought an e36 and inherited and mr2 over the years Name:  XyVIHIj.jpg
Pretty much stay off the forums after seeing a lot of the monstrosities people work on
MillerRS1 is offline
Old 08-10-2014, 07:12 PM
  #102
Docfishey's Avatar
Ive had my TC for 4 years now. Been on the site plenty but didnt break down and make an account till recently. Military I deploy a lot for time periods at a time, So site wise newbie, TC been around the block.
Docfishey is offline
Old 08-11-2014, 12:53 PM
  #103
05rs1's Avatar
Still got my 05 rs1 too....just got tuned and going to the track this sunday. hopefully i finally will see 10's. the car did good on the dyno and feels great. best was 11.4 last year. i will post pics and videos after im done on sunday.
05rs1 is offline
Old 08-21-2014, 01:54 AM
  #104
greddy05tc's Avatar
Originally Posted by GUNNIST14
Greddy05 did you mean Manley H Beams lol just kidding...what type of fuel pump are you running to hit 350-400??
Lol, yeah I meant Manley. I'm running a Walbro 255 pump.
greddy05tc is offline
Old 08-21-2014, 02:06 AM
  #105
GUNNIST14's Avatar
How did you modify your fuel pump assembly I have an aem 320 but it won't fit correctly
GUNNIST14 is offline
Old 08-24-2014, 10:33 PM
  #106
speedintc's Avatar
your gonna hack up the sending unit to make it work. when i made mine i basically cut off the entire bottom portion of it, drilled a little hole at the top and ran a little piece of metal rod thru it, put a little piece of rubber hose around it to minimize vibration, then i got two worm clamps and attached the fuel pump to that. im pretty sure someone has made a write up on how to do it somewhere on here.
speedintc is offline
Old 08-24-2014, 11:51 PM
  #107
GUNNIST14's Avatar
Speedinctc do you have any pics of this process?? I have a spare pump assembly that the AEM sits in and would appreciate any help..
Old 08-25-2014, 12:17 AM
  #108
speedintc's Avatar
i do not but i can go out to my car tomorrow and post back if youd like. im actually gonna be redoing mine because i dont like the way my fuel lines are setup.
Old 08-25-2014, 12:22 AM
  #109
GUNNIST14's Avatar
Yeah cool that'll help man thanks..
Old 08-25-2014, 12:26 AM
  #110
speedintc's Avatar
actually give me a sec im tryin to upload them right now for you.
Old 08-25-2014, 12:27 AM
  #111
GUNNIST14's Avatar
Cool
Old 08-25-2014, 12:32 AM
  #112
speedintc's Avatar
OG's Still around?-fuel-pump-setup.jpg you can see the rubber hose that i have put between the rod and the pump just make sure the hose if good for fuel because if its not then it will deteriorate in your tank.and the blue hose is for my return line. its a bit over kill so im buying a new sending unit and doin 6 an for feed and return lines this time around.
Old 08-25-2014, 12:39 AM
  #113
GUNNIST14's Avatar
Ok so is the pump fully secure without the lower bracket attached...
Old 08-25-2014, 12:42 AM
  #114
speedintc's Avatar
that is correct. i believe that you can use the bottom half if you drill it out but i didnt find it necessary so i made it this way. i think its easier.
Old 08-25-2014, 12:50 AM
  #115
GUNNIST14's Avatar
Ok If it's not too much trouble could post a step by step how to
