oil drain line
hey guys i got a few things to ask..
the oil drain line, do you think 12" would be long enough???.
and does anyone have a already tapped oil pan with the -10an fitting?? (if so ill buy asap)
thanks for all the help!!
No fitting, but I have a spare stock 2AZ oil pan if you want it. I ended up doing my return through the crankcase because the 1NZ pan is tiny, but this is what I used. it might fit on the 2AZ pan without needing to weld if there's enough flat surfase on the side.
http://www.summitracing.com/parts/SUM-220082/
12" willl work with a dezod manifold. Thats what length there kit comes with. I asked Paul awhile back. Just get there oil feed line kit. It comes with the brass fittings as well as the line.
kleecker
Apr 4, 2015 02:37 PM
