Oil drain line help
Does anyone have an oil drain line for sale? Need one end straight 10AN and the other end 45 deg 10AN also. 15" length (same as the Dezod oil drain line for the S1 kit).
Very simple to make this on your own. Just go to your local hot rod shop, (has to be a ton in northern n.j.) and buy the two fittings and 15" of steel braided hose. In fact, they would more then likely put it together for you if you asked. But if you can turn a wrench, then you can do it yourself. Like I said, its very simple.
kleecker
Apr 4, 2015 02:37 PM
