Oil Pressure Gauge Installation Question...
I've been trying to figure out how to install these gauges. Boost and AF seem simple enough. I'm a little stuck on installing the oil pressure gauge.
I've heard the Greddy sandwich adapter is the easiest thing to use...
However what are my other options? Can I use the stock pressure sensor? Can I T into something?
I understand how to power the gauge but getting the reading is what doesn't make sense to me.
Thanks, JOE
Thanks, JOE
appologies....
I actually meant the means in which the guage it'self will recieve the signal from the engine.
A mechanical oil pressure gauge will usually have a tiny plastic tube that the oil will trave through, thus creating pressure....just like a boost gauge.
An electric gauge will utilize a sending unit and electric signals (ohms?) to influence the needle...or in your case, the digital readout.
If this isn't completely accurate, somone please correct me!
yes, i didnt want a tube of hot oil running into the car... its a digital sensor with wires running inside.
this is what i have http://customizemyscion.com/store/in...roducts_id=146
Originally Posted by Ace83
T it using a 1/8 npt fitting
Oh yes...and use liquid thread sealer, if possible.
Originally Posted by paulky_2000
I meant in lieu of thread tape!
but i still wouldn't...eitehr way you probably wont' mes something up unless you out a glob in the damn hole.
i have used white tape for all my needs i do hvac im around alot more corrosive chemicals then one could believe Teflon holds up pretty well but as with everything proper use it what will get you the final result
omg.... stupidest effing thread ever.. i finally realize how this works.. so easy..
I was going to ask what goes into the T because there will be an opening and the piece that I was thinking of was the wire which nuts onto the sensor. For some reason I totally forgot about the sensor. Obvioulsy you just T into the block and stick the sensor into the T and connect the wire to the sensor to transmit the signal....
I cannot believe I didn't see this earlier.. So damn obvious that it makes me sick going into my senior year as an engineering student...
Thanks everyone, JOE
Originally Posted by aen
it's ok, i forgot to close my oil cap after changing my oil
we all make mistakes haha
Also left off radiator caps, tools under the hood, oil buckets under the car and lowered the jack, backed into another one of my cars in my OWN DRIVEWAY....
I could go on, but I think that's enough to establish me as a complete dumbass!!
