open loop 3 folks chime in....problem with idle
ive having problems with my idle after doing the open loop 3 mod....and im blow thru maf....problem is after i press in the clutch afrs go to 10.....slowly well within 10 seconds they hit 17's and bout another minute they even back out to 15...any ideas guys?
Open loop 3 is when you unplug your front o2 sensor and the ecu does not try and change the long term or short term fuel trims. This makes it easier to tune for partial throttle and keeps the computer from changing your fuel tuning.
gingles I think this is a specific tuning problem. You may not have enough resolution in your tuning device at low RPM so that you can accurately tune for idle. Maybe if you tell us what you are using to tune and maybe show us your map it may help.
looks a tuning issue.. on idle observe if your idle cell jumps around and observe the afrs as it moves around, myabe it just needs to be smoothened out.. or maybe its the high vacuum area needs to be adjusted. Seeing 17s on deceleration/off throttle/high vacuum should be normal and then it starts go back to idle afrs.
there set at 500 rpm intervals....come to think of it i could do that....hrmm...lowest ive ever seen idle was like 710...so i could start at 600, 700, 800, 1000, 1500, 2000, 2500, 3000, 3500, 4000 4500 5000, 5500, 6000, 6250, then 6500....hrmmm....finally i might have a normal idle
cid_mcdp
Jan 5, 2015 02:45 PM
