View Poll Results: Burning Cats w/ 9.5 pulley
Not burning
40.00%
Burning Cats
60.00%
Voters: 10. You may not vote on this poll
Question for the 9.5 guys
Old Jan 15, 2008 | 09:19 PM
kikcaffine's Avatar
Default Question for the 9.5 guys
How many other S/C owners running the stock headers and exhaust (axel back doesnt count) but using a 9.5 pulley are experiencing burning through cats or getting a CEL with the P0420 code?
Old Jan 15, 2008 | 10:16 PM
TimmyT's Avatar
Scion Society
i have no cel and still have the stock cat
Old Jan 15, 2008 | 10:19 PM
draxcaliber's Avatar
are you still burning animals?
why don' you just ditch the stock header and put on a non-cat'ed racing header? problem solved indefinetly until you have to show up for emissions testing.
Old Jan 15, 2008 | 10:26 PM
kikcaffine's Avatar
Exactly, until the emission testing comes into play......
Old Jan 15, 2008 | 10:28 PM
do what i'm doing, get a custom mid-pipe made with a high flow cat on it, and put the secondary o2 sensor behind that so you don't get a CEL and you pass emissions.
Old Jan 15, 2008 | 10:56 PM
BuddhasTC's Avatar
i have both cats still in place, stock headers, but a catback exhaust with the 9.5 psi pulley...i haven't experienced any burning
Old Jan 16, 2008 | 12:29 AM
HOLLYWD69's Avatar
I don't have a 9.5 pulley I have the stock pulley but I have burnt up a cat.
Old Jan 16, 2008 | 01:15 AM
ScottTc13's Avatar
Default Re: Question for the 9.5 guys
I have exactly this, plus now a blown head gasket. You might want to try the anti fouler trick it's only a few bucks and a little labor. I am picking up a MMW header with S pipe tonight that has the CEL Eliminator. So once I get it all back together, I think everything will be good to go. I haven't been WOT at all and at best I get 23mpg which sucks compared to others who claim 26-28. I hope after I fix everything the mpg gets better, and I go fasta :o
Edit. CEL came on before the 9.5 pulley was installed. As time went on the frequency of the CEL greatly increased. Before it was about week after I cleared it, it would return. Now it'll come back in 30 minutes or less. That header has to fix me up.
Old Jan 16, 2008 | 03:00 AM
Wyatt_Herb's Avatar
Killed two before I realized my motor was toast. Both times no CEL.
Old Jan 16, 2008 | 05:04 AM
BuddhasTC's Avatar
^^wow...that sucks
Old Jan 16, 2008 | 12:27 PM
chinito's Avatar
i am strongly considering the 9.5 and leaving my stock header (tx emissions every dang year!). why does the pulley burn up the cat? i understand that the s/c spins more, but if the afr is good, how should that negatively impact the engine and exhaust system? forgive my ignorance if i just put my boot in my mouth.
Old Jan 16, 2008 | 05:43 PM
gjpjr84's Avatar
i burnt up my original cat with the stock s/c back in november, abut 7 months or so after install.
when i got it back is also when they told me about the update to the TRD reflash
Old Jan 16, 2008 | 09:23 PM
kikcaffine's Avatar
Oh by the way I found a chunk of my first cat about the size of a razr cell phone when I pulled my Mid-pipe off. It fell out at the joint of the mid-pipe and s-pipe. So im assuming my first cat is toast. Its probably due to the increased heat and pressure due to the increased boost.
Old Jan 16, 2008 | 10:12 PM
Bravehearts's Avatar
that sounds like a great idea, but quick question if I was to put on a header, wouldn't i get a lot of rasp?
Old Jan 17, 2008 | 12:49 AM
Yankee21's Avatar
Meagan hedaer, invidia s-pipe, and draxas exhaust... I have a CEL but the cat is fine...
Old Jan 17, 2008 | 01:26 AM
kikcaffine's Avatar
put in an anti-fouler
Old Jan 17, 2008 | 01:31 AM
Yankee21's Avatar
Doing that next week...
Old Jan 17, 2008 | 01:46 AM
yeah, aftermarket header with aftermarket exhaust usually is a recipe for RASP, but with the addition of a high flow cat, and a nice big resonator or two, the rasp will be surpressed.
Old Jan 17, 2008 | 02:17 AM
Yankee21's Avatar
True that!
I have a high flow cat, and two resonators = sleeper...
Old Jan 17, 2008 | 04:00 AM
True that!
Thank you gentleman
