Question about e-manage blue
Old Aug 27, 2009 | 05:53 AM
BLUEhonor's Avatar
Default Question about e-manage blue
i'm buying streetstar's turbo kit and it comes with an emanage blue and a base map for 5-6psi of boost. my question is, would i even need to hook the emanage up if i only plan on 6lbs of boost? i know the stock ecu can take that, as i've heard from so many people running that same setup.
are there any benefits to hooking the emanage up if i only plan to stay on 6psi? the only reason i ask is because it comes with an 05-06 harness and i'm in an 08...idk if i should shell out for a 07+ harness unless there are clear benefits of doing so.
thanks in advance!
Old Aug 27, 2009 | 06:25 AM
Ace83's Avatar
Ronin Scion
yes, boosted with some sort of engine management is the way to do it.. the tune he has on the emanage may or may not work with you setup though, each car is different especially that you have the new gen tc.
Old Aug 27, 2009 | 09:24 AM
athletefeet66's Avatar
the turbonetics turbo is bigger than a typical stage 0 turbo so you will need management even at that low of boost. there are a couple people selling used harnesses for 07+ on here.
Old Aug 27, 2009 | 10:10 AM
Prototype_xB's Avatar
in short.....yes
Old Aug 27, 2009 | 02:03 PM
rhythmnsmoke's Avatar
Music City Scions
Benefits to hooking it up:
-Better fuel economy
-Ability to make more power with it, than without it.
bootlgr
Jan 26, 2016 01:22 AM
Greg S
May 28, 2015 12:46 AM
Scionxa180
Mar 13, 2015 04:39 AM
TotalChaos
13
Feb 4, 2015 10:24 PM
fearturtle44
15
Feb 13, 2004 01:15 AM
