Question about PiggyBack units for custom turbo kits
Old Nov 13, 2007 | 08:29 PM
16G-Scion's Avatar
Default Question about PiggyBack units for custom turbo kits
Are piggyback units such as the Greddy eManage or AEM FI/C really necessary for boosting the 2.4L engine on the TC?
even if I don't use massive injectors, can i run without a unit under safe boost like 6-9psi...im using a Saab t3 turbo. not looking for huge gains...maybe 250hp by the wheels 290-300hp at the crank.
Someone help me out here on this? I want to start gathering other parts for my custom turbo kit..
Old Nov 13, 2007 | 08:42 PM
etsnet's Avatar
You can try to get away with no piggyback but your motor won't last without one on the PSI/power level you are looking for.
If you go for a 200-220 range on no more then 6psi and stock injectors you could get it to work but it might run a little rich.
Old Nov 15, 2007 | 02:33 AM
16G-Scion's Avatar
what if I find a larger set of injectors close to 440cc?? does it make a difference..what do you recommended as a inexpensive piggyback?
Old Nov 15, 2007 | 01:51 PM
etsnet's Avatar
I think anything bigger than the stock will make you run way too rich without a piggyback.
An inexpensive piggy back is a the emanage basic aka blue. It will probably be the cheapest out of all of them and you can always buy a used one.
Brammi
Nov 13, 2016 03:46 AM
cessblood
Sep 15, 2015 06:50 AM
drobins27
10
Feb 2, 2015 02:10 PM
jdstC1
Jan 13, 2015 04:45 AM
greytc
Jan 12, 2015 09:49 PM
