S/C pulley help!
sorry for so many dang questions, but does the s/c kit usually come with the key that unlocks the crankshaft bolt that holds the s/c pulley?
it is b/c i want to install the 9.5 nst pulley, but how do i take it out? any suggestions?
Well depends on what year your car is I think they changed something for the 07-08's but if it didn't then all you have to do is get a heat gun nd heat up the cover and then gently start pulling the cover go to trdsparks and pull up the instructions on how to do it nd that'll give u an idea on how to take it off
No no no, not heat the bolt, if a dealer installed your s/c then they most likely put on the s/c pulley bolt cover<---(not the real name I just forgot) and what they do is heat it up nd mold it over the bolt and then when it dries it stays on the bolt if u heat it up it will eventually come off jus b careful if u r worried about warranty work
NonStopTuning
Scion FR-S Drivetrain & Power
14
May 5, 2017 06:52 PM
xjleitex15
Aug 18, 2015 01:23 AM
xjleitex15
Aug 17, 2015 12:09 AM
