S1 kit cut
Old Apr 3, 2008 | 01:22 AM
JL56TC's Avatar
Default S1 kit cut
I am getting a serious fuel or ignition cut at about 4k-6k anyone have any ideas... i have run 105 for 3 tanks now... it got a lot better after I mad the switch to the higher octane but it still does it.... any idea (too cold plugs)( not enough fuel).. My A/F are great.. it runs a bit rich most of the time which is fine. The only other thing I can think of is to run a little more boost and see if it doesn't clear up... any thoughts
Old Apr 3, 2008 | 01:33 AM
draxcaliber's Avatar
what are you using to tune it?
Old Apr 3, 2008 | 01:51 AM
TurboToyotas's Avatar
its the tune....has nothing to do with the kit........
When you changed your fuel did you retune for it?
Check your 02 sensors as well, they dont like allot of high octane fuel. Especially if you go back and forth allot.(switching between pump and high octane)
You need a set for pump gas and high octane
Regards-
Todd
Old Apr 3, 2008 | 01:59 AM
JL56TC's Avatar
AEM and actually we re tuned it for 105 I use the same gas as I always do so It should be fine... how ever I haven't pulled the plugs yet to see if they might be a little too cold...honestly I think its an ignition cut.. although I think I might have some compressor serge which doesn't help
Old Apr 3, 2008 | 03:16 AM
sciontcnp's Avatar
what u using to monitor AFR? check for fouled plugs and o2 sensors and i imagine that race gas is ____ing it up especially if it is leaded... why 105?
Old Apr 3, 2008 | 06:15 AM
Mr_Meaty's Avatar
what do you consider "a little rich"?
what exactly are your AFRs at when you get the cut?
Old Apr 3, 2008 | 01:41 PM
paul_dezod's Avatar
Scionetics
KAD
Regards-
Todd
Spot on Todd. Exactly what I was going to say.
You might have fouled out your plugs and/or O2 sensor. Please check them all, retune and report back.
Old Apr 3, 2008 | 01:42 PM
paul_dezod's Avatar
Scionetics
KAD
Rather doubtful if it's an off the shelf S1.
Old Apr 3, 2008 | 07:24 PM
JL56TC's Avatar
doubtfull on the compressor or the igniton couse im open to anything right now
Old Apr 3, 2008 | 07:50 PM
satoman44's Avatar
change your plugs to 1 or 2 step colder than stock with a proper gap. maybe around .035. your plugs might be gapped to wide or maybe its too cold? when my gap was too wide, i was having this problem. sounds like fuel/ignition cut but i don't think its really that. once i changed plugs with a proper gap, it went away.
Old Apr 4, 2008 | 02:56 PM
JL56TC's Avatar
fixed.... got new plugs.... runs great....12lbs wheeeee
Old Apr 4, 2008 | 03:30 PM
paul_dezod's Avatar
Scionetics
KAD
LOL
Sometimes it's the simple things that screw us up. Glad to hear it's resolved.
Old Apr 5, 2008 | 09:58 PM
Scott8's Avatar
don't you wish everything was that easy of a fix!!!
Old Apr 6, 2008 | 06:19 PM
JL56TC's Avatar
lol... heck yeah
Old Apr 6, 2008 | 06:21 PM
Scott8's Avatar
what part of St. Paul you at? I am up there visiting family next weekend
Old Apr 6, 2008 | 06:27 PM
JL56TC's Avatar
Falcon Hights aka Roseville area... come and see me
Old Apr 6, 2008 | 06:34 PM
Scott8's Avatar
I'll PM you if I get a chance to break away from the family when I'm up there.
Old Apr 6, 2008 | 06:38 PM
JL56TC's Avatar
ok cool... hope terry will be done with his TTC by then... maybe we can go for a drive
Old Apr 6, 2008 | 06:55 PM
Scott8's Avatar
that's what I was hoping for
Old Apr 7, 2008 | 02:12 PM
Enrique_Dezod's Avatar
Glad to seeee all is well
cessblood
Sep 15, 2015 06:50 AM
SkillFreeJake
Scion tC 2G Aero & Exterior
Jul 27, 2015 12:34 AM
clickclickw00t
Feb 18, 2015 08:57 PM
Scion0814
Scion tC 1G Aero & Exterior
Feb 15, 2015 10:02 PM
NewBox06
Feb 3, 2015 04:02 AM
