SAFC-II install HELP NEEDED
ok i got the wiring diagram for my 07 from here
http://www.dezod.com/files/tC%2007%20Pins.pdf
i connected everything from what i know to be correct, but when i turn the power ignition all i get on the AFC is the dial to light up. I don't think it would be a ground because if it were the dial wouldn't light up either. Does the safc not turn on if there is a bad connection or a connection going to a wire that its not supposed to be? any help would be appreciated.
here's where i connected the wires.
ground(brown and black) --------> E8-3 (E1) (Brown 2 inches closer than Black)
Throttle(Gray)------------------> E8-20 (VTA1)
kncock (Purple)----------------->E8-29 (KNK1)
RPM (Green) --------------------> E5-1 (TACH)
IG power (Red)------------------> E4-1 (+B)
Air Flow (Yellow to ECU, White to Harness)----> E7-28 (VG)
hey, im not sure how to do it, but my local tuner, is gona tune my turbo setup, and he said screw the emanage lol and get an AFC by apexi or the AEM....since im low on cash, im gona pick up the neo afc by apexi and take it to him to tune it with, this guys really good w/ this computer, when i do taht i can let ya kno lol but i suggest taking it to a professional. Im gona use the apexi till i can afford a whole AEM setup, and maybe fig. out a way to use the neo as a data logger and tune w/ the AEM
Beesh
01-09-2015 06:30 PM
kleecker
01-09-2015 02:26 PM
rancur3p1c
12-19-2014 04:30 PM
TheRedBox
31
12-02-2003 04:53 PM
