Serious help code p2196 and p0304
Old Apr 5, 2013 | 04:12 PM
Beckenbauer's Avatar
Music City Scions
ive got wrenches with extensions, 12mm 10mm sockets, screw drivers and what not lol the only thing I dont have is a torque wrench...
Old Apr 9, 2013 | 12:58 AM
Music City Scions
Update so I have new intake manifold gasket on Saturday... Check light came on today... I have no idea what to do now... This is confusing as crap
Old Apr 9, 2013 | 01:08 AM
BlackKnight's Avatar
Music City Scions
Do compression test dry then wet.
Sent from my SGH-T999 using Tapatalk 2
Old Apr 9, 2013 | 11:46 AM
Music City Scions
Compression test came back all cyl good. Is it possible that I could have a brand new o2 that is fouled already? Would the o2 be fouled from excess gas causing it to be stuck rich aka fouled. I fixed the vac leak in the manifold but could it be possible the o2 is fouled still?
Old Apr 22, 2013 | 01:53 AM
spray_for_spool's Avatar
Hows the car start up? extended crank? Any smoke? missing any coolant?
Old Apr 22, 2013 | 01:55 AM
I didnt read all of this thread, just skimmed it...did you replace the 02 with a Toyota unit?
Old Apr 22, 2013 | 12:40 PM
Music City Scions
yes replaced a/f o2 and rear o2 recently after I fixed the intake gasket now everything was fine no more p2196 or p0304 codes. BUT now I have the lean code p0171. all vac lines are good no smoke no extended crank (for the most part) sometimes it takes a tad "little" longer than usual. no missing coolant. check light comes and goes. yesterday plugged up a friends tech 2 scanner and the light went away after we starter the tc...weird bc we didnt clear the codes just had it plugged in. he is a certified tech and said he has only seen that once or twice in his 30+ yrs as a mechanic. he also said that the lean code is probably due to a old MAF sensor...ive only got 132k miles so who knows. ive cleaned the MAF twice within the last 20k miles. could be that it needs to be replaced now too...
Old Apr 22, 2013 | 12:44 PM
P0171 is a MAF on our cars. Cleaning it doesn't always work and can actually cause damage. Time to replace it. I may have one in my toolbox I can send you o
Old Apr 22, 2013 | 04:26 PM
Music City Scions
I actually just ordered one, but thanks anyways! hopefully this will work lol
Old Apr 23, 2013 | 01:41 AM
That_Kid_Ju's Avatar
How's the O-Ring on your MAF? I need to replace mine cuz it's all stretched out. Would you be willing to send to me?
Sgtfluffy16
Regional - Northeast
Jul 28, 2021 10:32 PM
eujin
Feb 23, 2016 01:18 AM
That_Kid_Ju
Sep 30, 2015 10:05 PM
Sgtfluffy16
Sep 30, 2015 01:42 PM
jeremydoc
Sep 16, 2015 11:31 PM
