should i go for more power
ptuning just tuned a 1st gen tc stock internals to 13.5 psi making 351 whp,.....dont know how long that would last.12 psi can be done,but like all have said...its all in the tune and well you take car eof the car,im at 9 psi psi making 300 whp....which is fine for me.....its all about preference...and $$$$$
speaking from experience, boosting upwards of 10psi will shorten the life of the stock engine. You should go to 3" exhaust at minimum and stay within the 10 range to lengthen engine life unless you plan to build. You also might want to install an LSD to get full use of HP you already have (did not see where you mentioned if your ride had this installed). As for boost controllers, some work some don't. Each is dependent on the car it is installed on.
Exhaust is going to depend on the kit to an extent. I ran the descendant kit on 10 psi with stock exhaust except for an axle back and it ran perfect. New 3" exhaust and boost creep brought that to about 12 psi. Had to adjust fuel. Then when colder air came, October/November time I was seeing anywhere from 13-14ish.
The wastegate was too small for the turbo and 3" exhaust. Upping boost and building engine so it won't be an issue but its something to ask about.
i would def need a 3 inch exhaust...but i would have to get a custom one done........nah i dont have LSD att he moment,it would def help out....i have a turboxs manual boost controller,i def wanna hit the 350 hp range......
Build the motor if you wanna up the boost and push big numbers. Also, make sure you don't exceed the manifold's capability. I believe the log manifold is good up to 350 hp. I too wanna get bigger hp numbers, so I'm switching to a 3" exhaust. Currently tuned at 11 psi, but only run 7 daily (10 if I feel spirited). You might wanna start looking at the alpha kit...
Just 2 examples of what she can do
i would love the alpha kit....just not right now lol......how much max power can my garret t3/t4 57 trim .63 ar turbo make with my 550 cc injectors..curious..is it around 350 mark
most people perfer .30....which i think is good up to 18 psi....but thats between you and your tuner
ScionLife Editor
02-25-2015 04:40 PM
crystaljukebox_com
02-05-2004 05:53 AM
