sleeve block
im getting the tc sleeve this week but idk which way i wanna go with if i should just stay with the 89mm bore or i think its the 92 mm. plz help me out thank you very much any advice would help. can some ppl hit me up with some of the number they are pushing and what sleeve mm they went with thank you.
I think, and I could be wrong, if you stuck with the standard 89mm bore, you can rev a little better. Like if you plan on reving high enough, it's recommended that you stay with the standard bore.
o ok thank you. i got the piston already but still having lil doubt that 89mm would just be ok. but 92 mm would be better. but if 89mm is a better way then yea prob just do that.how i can get more info thanks
yeah thats true but you can just messure your cylinders to make sure they are ok. and they usually already come cated with cast iron. oh and you just need to hone it to make like new again.... i'm just trying to save you some money
yeah just research some more no need to spend money were it isn't needed if i would to build an engine which will probably be in the near future then i would focus on cooling, lubrication and the stength of the connecting rods, bearings, and bolts. oh yeah don't forget about precision measuring, and super super clean block and area to work in
i would stick with 88.5 stock bore size. this way, after x amount of miles when your internals finally wear down, loose compression, and score your cylinder walls. you will most likely have to bore it out then to fix any scratches. this way you get the most miles out of your sleeves.
i dont know if you've taking the head off yet, but the stock sleeves are so thin its scary!!! they look like they are about 1mm thick, if your going to go to 89mm i would recommend sleeving the block, and 92mm is bigger than the bore and the sleeve diameter easily
i was hoping to use the stock sleeve for a 89mm bore piston...then i took the motor apart and saw those wieny sleeves, i wouldnt risk it, get it sleeved, you'll have much more confidence in your motor
