sleeve block
Old Oct 16, 2008 | 01:58 PM
coryjames's Avatar
Originally Posted by brett561tc
i would stick with 88.5 stock bore size. this way, after x amount of miles when your internals finally wear down, loose compression, and score your cylinder walls. you will most likely have to bore it out then to fix any scratches. this way you get the most miles out of your sleeves.
good idea but using dartons replacment sleeves can be had for 120 bucks for a single and you can do the install your self on great thing about dartons mid install kits thats what i run
Old Oct 16, 2008 | 01:59 PM
rhythmnsmoke's Avatar
Music City Scions
^^So your build is done Cory?
Old Oct 16, 2008 | 02:00 PM
coryjames's Avatar
another point our motors stock dont have sleeves they have piston liners they are about 1.5 mill thick and fragile you can stop on it and bend it most aftermarket sleeves including darton you cut out all the aluminum in the cilinder wall and replace it with the ductile iron so you go from 1.5 mill to about 10 mill
Old Oct 16, 2008 | 03:54 PM
ScionCREW's Avatar
Originally Posted by Ace83
why not 92mm on boost? wouldnt the stronger sleeves be able to handle the bigger bore?
yes the sleeves can handle the bigger bore for N/A but not the boost. the problem is at 92mm the piston bores are getting too close to each other. At that point is where the sleeve is the weakest. there is a maximum bore for turbo motor, any sleeve manufacture can tell you what it will be if you give them a block to do measurement on.
Old Oct 16, 2008 | 04:01 PM
coryjames's Avatar
90mm is the most you can go under boost to be safe and thats on aftermarket sleeves ask erl or darton or anyone thats the top lol
and rhythem my build is close waiting on some other things block is done lets say its sexy got alot of goodies done to it upped oil flow passages to squirters and stuff still waiting on cams and what intake mani will make it to the market first till the motor goes in with the cams im leaving stock ones in going to tune it throw in the stage2s see how much more power i make at the same psi
Old Oct 16, 2008 | 04:28 PM
Music City Scions
^^Not bad, waiting on your outcome.
Old Oct 16, 2008 | 04:31 PM
coryjames's Avatar
yeah lol lets just say the gt3076 might be running a little hot lol im going to max that bad boy out
Old Oct 16, 2008 | 04:51 PM
Music City Scions
^^That's my plan as well. GT3076R FTW!
Old Oct 16, 2008 | 05:15 PM
azntct's Avatar
how much power can stock sleeve hold normally?
and how far can you bore before4 needing sleeve?
Old Oct 16, 2008 | 05:23 PM
SoFloTC's Avatar
im not sleeving while doing my internals.. im using 89mm pistons and going for 375-400whp on my auto..
will i be ok?
Old Oct 16, 2008 | 05:32 PM
Music City Scions
^^You have to start worrying about the tranny handling that much. I think even 300whp has not even been seen yet on an Auto.
Old Oct 17, 2008 | 03:46 AM
purevision01's Avatar
will i be ok?
Like rhytmnsmoke said, the tranny will need at the very least a shift kit installed... But at 400 on a block with atleast rods should be ok. You will obviously be going to clevite bearings, arp studs, and some kind of racing mls head gasket.... The only part of the bottom end that can be reused from the factory after tearing down the motor are the bearings.
Old Oct 17, 2008 | 04:21 AM
azntct's Avatar
made the decsion, sending it to golden eagle tuesday to get sleeve
Old Oct 17, 2008 | 12:44 PM
SoFloTC's Avatar
.. i have a built auto tranny from LevelTen.. its good for 350-400whp. with perfect shifts but like i said if i dont sleeve will i run into problems?
ya im using ACL bearings, K1 Rods, CP pistons, Cometic gasket and ARP studs.. then my shop said there gonna get a new head and put stainless valves in aswell for me. Im def breaking it in all motor tho.. i wouldnt want to make a mistake and enter boost lol.
Old Oct 17, 2008 | 02:21 PM
coryjames's Avatar
rythem you want to buy my gt3dr
Old Oct 17, 2008 | 02:49 PM
Music City Scions
^^I've spent quite a bit over the past couple of days, so I'm a little strapped right now to buy it. Otherwise I would be all over it.
Is it a 71 or 76r?
Old Oct 17, 2008 | 03:20 PM
coryjames's Avatar
Old Oct 17, 2008 | 03:25 PM
Music City Scions
Nice, wish I could scoop it up from you.
Old Oct 17, 2008 | 03:37 PM
KillaSmit's Avatar
Default Re: sleeve block
Stock Bore / Golden Eagle
Originally Posted by azntct
im getting the tc sleeve this week but idk which way i wanna go with if i should just stay with the 89mm bore or i think its the 92 mm. plz help me out thank you very much any advice would help. can some ppl hit me up with some of the number they are pushing and what sleeve mm they went with thank you.
Old Oct 17, 2008 | 04:32 PM
azntct's Avatar
thanks
