stage 0 oil return line melting?
Well it looks like my oil return line is starting to melt a little bit. any advice before this turns into a mess of oil all over my downpipe?
What did you use for an oil return line? How did you route it?
Are you running a stock exhaust? Are you doing warm up and cool down cycles at idle after you finish playing with your toy?
I've been running a lot of AC for the two weeks that my cars been turbo -Maybe the constant AC fan is helping to cool down my oil return line.
Here is a picture of my oil return line routing.
Here is a pic at the oil pan
That's a 45-deg brass elbow that I'm using in the photo's. If you choose to route it like me then the line only needs to be 16" long -but it may vary with the angle you clock the turbo. Once you lossen the center cartidge clamp and the snap-ring on the cold side of the turbo you can literaly move the oil cartridge and the return oil line nipple to where you want which is typically as far away as possible from the down-pipe. You can also wrap the line in alumimun tape to help protect it against heat.
I've found a special 407 stainless steel corrugated hose that should be a perfect fit for the ZPI kit as an oil return line. I'm still working out a source -I'll update when I can get it all setup.
Ahh good news.. the great guys @ ZPI are sending me a new oil return line :D Thanks again guys ('n gal)! Hopefully I wont have to clock the turbo too much to run the return line in front of the dp.
I had that same problem... routed poorly and after only a couple days the outer layer of the oil return line. It held up for months, though. (Mine was different from the one in the picture.)
I got a DEI Cool Tube Extreme to cover the new one and so far so good!
carid
03-30-2015 07:08 AM
