Stage 0 outlet flange
I bought a used kit and was wondering , what is the small barbed fitting coming off the outlet flange for? tried a search and could find nothing about this. Thanks
Nope. I know what the oil return is. It is like a little vaccum barb fitting a little bigger than the vac line for the boost gauge. It is located right on the outlet flange atatched to the outer wheel of the turbo.
the outlet nipple is the 1st place that will be charged to 5-6psi and you run a line from there to your external wastegate. also for a boost guage you have to use a source that is from the trottle body or the intake manifold. because you need somewhere that will show boost and Vaccume
Not saying your wrong , because obviously i don't have a clue , but why do most people T into the line coming from the back of the valve cover or throttle body. Wouldn't this fitting be the best place then? Which is best? Thanks for helping out.
my system is set up that way with the vacumm line running from the turbo to the wastegate. theres pics that oyu can see how its hooked up on the third page of this thread. https://www.scionlife.com/forums/vie...+kit&&start=20
