Stock MLS Head Gasket
Old Mar 31, 2010 | 04:56 PM
thendawg's Avatar
Default Stock MLS Head Gasket
I pretty much can get a new Toyota head Gasket for free, its an MLS and others have done their builds with them, so Im sure it will hold up. However, does anyone know what the bore on the stock gasket is? I will be running a 89mm bore and am wondering if I could still run one - I know many car manufacturers sometimes run a gasket up to 1mm over the stock bore size, so just curious.
Old Mar 31, 2010 | 07:12 PM
trd07tc's Avatar
I know cometic recommends going .5mm over on head gaskets.. Never heard of going the other way
Old Mar 31, 2010 | 08:19 PM
thendawg's Avatar
Yeah, its always recommended to run .5 mm over the bore size - however it appears no one makes 89.5 mm HG Im also wondering if the stock HG is actually 88.5 or 89mm - Which HG are you folks running 89mm bore using??
Old Apr 21, 2010 | 05:32 AM
thendawg's Avatar
Sorry to ressurect this thread - but hey easier than making a new one So typically with most HG you want to go .5mm over bore size correct? Im going with 89mm bore/pistons. My question, is the Cometic for an 89mm bore, or is it an 89mm headgasket for an 88.5mm bore? Either way, those of you running 89mm bore, what hg are you usin??
Old Apr 21, 2010 | 06:11 AM
m6ar2cel6oTC's Avatar
I'm using the one that dozed sells on there site.
Old Apr 21, 2010 | 08:41 AM
RusWolf's Avatar
I use the one that came with to me from ERL with the block. i believe its 89mm cometic MLS and my engine is bored out to 89mm.
Old Apr 22, 2010 | 05:31 PM
a-mendoza's Avatar
well havent quite done my build yet but i already bought a 89mm cometic gasket and i too am doing 89mm bore. Hope i didnt buy the HG too soon.
Old Apr 22, 2010 | 05:58 PM
ElevationTC's Avatar
I used oem on both 88.5 and 89 blocks with 0 issues
Old Apr 22, 2010 | 06:03 PM
brett561tc's Avatar
you should go with the 90mm cometic.
http://www.raceeng.com/c-4038-gaskets.aspx
wiltonhall
Jun 23, 2025 10:09 PM
SloTC1
Apr 2, 2015 07:11 PM
PTUNING
Dec 6, 2014 03:58 PM
darkshadowofxdeath
Dec 3, 2014 06:59 PM
Jamster
Nov 20, 2014 07:49 PM
