Suddenly running rich[help]?!?!
So tonight i was driving on the highway and i got up to full boost a few times, and hit about 100 in 5th. When i got off the highway i noticed my car was/is running waaay rich. At idle the car is at like 12 and driving normal, it gets down to 10. when i boost again it gets leaner till like 14 then starts going back down to 11.5-12 which is what it is usually at when i boost.
i am running the AEM FIC, with the Dezod S1 kit at about 10-11 psi. It was running perfect earlier. IDK what happened, all i know is it was pulling wicked hard, kinda liked it, but don't want to run rich all the time.
Please someone help!!
i was thinking the same thing about the vacum and charge pipes, but if one of those blew wouldn't i be running really lean.
Can my fuel trim just change? i didn't touch my tune at all.
Originally Posted by 08superwhite
yep definitely check you piping for leaks. I have this happen to me every now and then. especially if i scrape pulling out of a parking lot. one of my intercooler pipes is pretty low
Originally Posted by nlataille18
how would a leaking charge pipe cause me to run lean? only would like to know because i just happened to have scraped a little last night....
because your maf sensor already added fuel for the air coming in through the turbo. then it is coming through the turbo and instead of going into the engine it escaping at the leak in the intercooler pipes, but it is still adding the fuel for the air that never made it to the engine. that is why you are running rich
oh i see. i thought it would suck more air in and make it lean. well i'm going to go out and check my pipes now. thanks guys, and if that isn't the problem I'll post back!
so i went out and checked all my pipes and they all seemed to be on there so i gave them all a little tighten and started my car up.... this time it was idling at 10 so i got a spray bottle with soap and sprayed all my couplings and none of them were leaking.
I pulled my negative cable off my battery to reset my fuel trims, and viola!! Like magic... now the hard part... can anybody explain to me why this happened, this is the first time it's done this, and i would like to know if i could prevent it. Maybe cause when i went from 100 to 70 i left it in gear and let the trans slow me down. Does anybody know if that's bad for your car, i wouldn't think so but then again i can be wrong.
so lessons learned... check your pipes and reset fuel trims (btw is it bad to reset fuel trims?)
RY_TC07
Jul 18, 2017 05:18 PM
CapnChunk
Apr 13, 2015 04:06 PM
