supercharger f'ed
so basically a long story short, i was duped by a member here on the forums, i traded some stock parts plus cash for an entire supercharger assembly and kit. the trade went very smoothly and i expected a mostly usable charger except maybe replacing a couple bearings which was no biggie, but when i pulled the pulley side apart to rebuild i found that the two bearings were so bad they fused together as well as fusing the pulley to the first bearing. and the worst of it all is when the bearings went out they ground the shaft down by a 1/8th of an inch therefore the bearings will not fit the shaft which now has to be replaced as well. so basically this rant is to ask if there is anybody selling a GOOD shaft and maybe even an entire pulley side assembly for any year i don't care. if no one is selling any shafts then point me where i can get one, i know i can get one from gompka but he is currently not offering them according to his website.
hey werewolf if you dont need the cast aluminum bearing mount/housing (don't know the technical name but its on the green rag in picture 1) then i'll buy yours or his. that should soften the 100 to 150 you are paying for.
i may need a replacement housing for the pulley side myself, the one i have has been damaged on the inside, i'm not sure if it matters since the bearings' inner race is the only moving part, when i say damaged i mean it is scuffed with a few nicks with the inner diameter still the same.
I will be making another batch of shafts, lots of interest lately as a bunch of s/c's have died lately. I'll have more info asap, I say for now take off the shaft side, put on your stock belt, put on stock intake, and you can drive your car like that with the blower side still attached to the car.
let me know if you change your mind, gompka says you wont need the new one. i have been calling around to get mine welded because i cant find someone who is selling theirs. i just figure i would be cheaper to buy yours then the weld.
ok so i got the new shaft and have new bearings on it, thanks GWTC, anyways, i now need to press this shaft with bearings into the housing and the bearings are currently pressed onto the shaft, what is the best way to get them into the housing without damaging them if i can't get a bearing press. everyone around here wants to charger over a hundred bucks to press them in. any ideas?
https://www.scionlife.com/forums/sho...d.php?t=178268
Read post #11 and #20 for tips on what to look for and what you might need. The part that I talk about in post #11, if you can I would have that piece welded together instead of putting JBWeld on it, if you can I would do it to the other piece that it mates up to, the one that connects to the blower, hope that helps and good luck. I had another incident with my set-up and I will be making a new post about, it has info that I feel everybody that owns a SC should read, I'll try to have it up by today or tomorrow.
well i hope i'm able to get them in then because it just dosn't seem to want to go without being pressed. if they have to hammered out then how come they can be slid in place, maybe i'm missing the right tactic or something. also i read your posts you suggested and i'm not sure of where you are putting the loctite and i'm sure getting it in the bearings would be really bad lol.
would putting grease on the inside of the housing help slide it in (so to speak) and if so, how would i apply the loctite if there is grease coating the housing walls. i'm also thinking of installing a grease fitting. i checked your website Gompka on installing the grease fitting but i couldn't find anything, i'm assuming its as simple as drilling a hole between the two bearings and then tapping to so it has threads and then thread in fitting, push some grease in and viola?
https://www.scionlife.com/forums/sho...d.php?t=164208
and your shaft in the refrigerator. then follow what GWTC said and DO NOT use grease to help slide it in. i just tried it and it works really well
Isn't the housing made of aluminum? if so wouldn't it be a bad idea to heat it up? doesn't aluminum warp when heated up? I don't know thats what I was told, but maybe 250-300 is not enough to do anything to it.
thats what the shop that has been working on my bearings told me to do and it worked great for me. that mount is so close to your engine it is reaching relatively high temps every time you drive. if you want to be on the safe side do 200. with a melting point of 1220 F you have nothing to worry about
rain7905643
Jun 13, 2018 05:29 AM
