Supercharger / Oil Catch Can Set-up
Old 04-04-2007, 04:20 AM
mike6789k's Avatar
Originally Posted by jetlounge
I've heard conflicting stories on joining PCV and breather, so I opted to keep them separate. Still all the same bits and pieces, just with a filter in between them now.
it really isnt though...
on a stock tc, the pcv is in constant vacuum, but now in your FI tC, the pcv is under boost alot of the time, so it has trouble venting properly... you need to move the outlet to a source of constant vaccuum...
mike6789k is offline
Old 04-04-2007, 05:04 AM
jetlounge's Avatar
i thought the prob was that the pcv on the tC leaked boost...
jetlounge is offline
Old 04-04-2007, 05:06 AM
mike6789k's Avatar
never heard that one before... its a possibility though...
but the main problem is the boost isnt alowing the blow-by to fully escape from the pcv
Old 04-04-2007, 05:15 AM
jetlounge's Avatar
but is that necessarily a bad thing? pcv closed means boost held. pcv left constantly open means boost leak, right?
Old 04-04-2007, 07:56 PM
mike6789k's Avatar
the pcv is one way, it only lets stuff out, but if there is boost in the line, the pcv will stay closed and blowby will not vent from the engine.
Old 04-06-2007, 06:39 AM
Wyatt_Herb's Avatar
Which in my opinion is the cause of every destroyed motor that was running a supercharger.
For informations sake: what happens when blow-by isn't properly ventilated? Can sludge build-up contaminate the fuel?
Wyatt_Herb is offline
Old 04-06-2007, 06:59 AM
hotwheelsrs1's Avatar
ok so do we really need to can up both the lines?
hotwheelsrs1 is offline
Old 04-06-2007, 04:07 PM
jetlounge's Avatar
every "destroyed" motor that was running an s/c??
there are many documented poorly installed s/c's..but destroyed motors? how many do you count of those?
i think you are making a huge leap here.
Old 04-06-2007, 04:52 PM
mike6789k's Avatar
yea lol you dont destroy motors with a clogged pcv... but you can cause some problems...
Old 04-07-2007, 08:43 PM
jetlounge's Avatar
i don't think its only one way. thats the intention, but under boost it will get pushed. and you'll lose a little hp.
this is most likely why when some have capped the nipple on the intake mani and routed the PCV out to vaccum they got a little more oomph...not because pcv vapor couldn't get out before the cap off, but because boost was pushing in.
so a PCV for boosted applications would be in order..and a better vac solution for the breather. air will take the path of least resistance.
at the end of the day, the catch can is just a bandaid to the blow-by problem
Old 04-08-2007, 05:44 AM
Wyatt_Herb's Avatar
I've been through two motors myself and destroyed a couple cats, which from what I understand is caused by a lean condition...hence the question, can blow-by cause sludge build-up, contaminate your fuel, lower your octane, cause detonation, destroy a cat...etc. etc.
There hasn't been many but it has happened. Look at Equinox. Where does the oil go that seems to disappear? I am just looking for an explanation.
Once again I've been through two motors both of which were missing 45 psi in hole #3. How do you lean out a motor with the "safe" TRD map? I'm not trying to argue I am just dying to know. Is there a difference in the dynamic between a turbo and supercharger when it comes to blow-by?
These threads led to such assumtions:
https://www.scionlife.com/forums/vie...ighlight=catch
Old 04-08-2007, 06:36 AM
mike6789k's Avatar
cats are destroyed by rich conditions
Old 04-08-2007, 08:22 AM
tC9o9's Avatar
who needs cats anyways?
tC9o9 is offline
Old 04-08-2007, 11:13 PM
Wyatt_Herb's Avatar
Even stranger. . .
Old 04-08-2007, 11:15 PM
jetlounge's Avatar
Even stranger. . .
yeah. i always thought cats were destroyed by dogs.
Old 04-08-2007, 11:24 PM
Whocares05050's Avatar
Thats what i say
Whocares05050 is offline
Old 04-09-2007, 02:52 AM
mike6789k's Avatar
Even stranger. . .
Old 04-09-2007, 03:48 AM
fox
fox's Avatar
I don't know if this will help because it's on a turbo setup?
fox is offline
Old 04-09-2007, 03:53 AM
mike6789k's Avatar
thats the idea... but the PCV would be a better choice to use instead of the breather (which doesnt NEED a vacuum source and could just be VTA
Old 05-02-2008, 08:56 PM
hunterUnknown's Avatar
hate to resurrect a thread but i need to install a catch can as well.
my cat just died. (that sounds sad)
but yeah, its getting replaced now. and a quart of oil magically disappeared. ive only been s/c for about a month. 3000 miles-ish.
helpful info guys!
hunterUnknown is offline
Quick Reply: Supercharger / Oil Catch Can Set-up
